lastwish
Enter your message here...
Post by lastwish on Dec 26, 2018 14:25:51 GMT -7
Yes those are oem.
And as for preload setting, I maxxed it out a while back.
From stoltec's report the oem spring is too soft for a rider of my type, approx 200 lbs geared and I concur. One day I'll outright upgrade it, but paying off the bike will come first and then carbon fiber wheels THEN a full suite of Ohlins.
From the dealership the preload was around 1/4 compressed in, then I tried 1/2, then to 3/4, then to maxxed out. All with a week or so of riding in between each adjustment.
I also swapped the oem dogbones back in, the raising up links just threw the bike off too much, too many compromises in ergonomics too. I got the answer I was after in the end, there will be no magic trick to emulate the setup I had on my fz1. The trail / rake differences and possibly wheelbase are not worth changing to me.
aavmann
Post by aavmann on Apr 13, 2019 12:17:52 GMT -7
I dropped the yokes 20 mm. Turns much better now. I did the same as per Dave Moss's direction. I agree...steering feels better but the biggest difference that I have seen, and the one that makes this mod SOOOO nice for me, is that the bike gets the power down with FAR LESS wheel lift. As mentioned in a few of my other threads, the wheelies were becoming annoying and I have less than 1000K on it. Mode 1, however, doesn't give a rat's ass what steering geometry you have or suspension settings, and sends the front skyward. Mode 2 with a nice hard roll-on, accelerates like crazy and very gently starts raising the front end. I only have a few hours of seat time with this change but absolutely love it so far. Easy to do too...
theculturalattache
Post by theculturalattache on Apr 13, 2019 13:17:47 GMT -7
Glad you liked the mod.
Since dropping the yokes 20mm I have fitted an aftermarket shock that is length adjustable, so have raised the rear end 10mm.
Have gone back to stock position on the yokes for the time being as being a heavyweight I am constantly bottoming out the forks even with max preload.
Will be having a fiddle again when I get stronger springs fitted in the forks.
theculturalattache
Post by theculturalattache on Apr 13, 2019 13:23:21 GMT -7
Will probably aim for plus 10 mm in the rear, minus 10 mm in the front and experiment from there.
lastwish
Post by lastwish on Apr 16, 2019 2:41:15 GMT -7
I just couldn't deal with those altered headlight and seat angles. I commute and hoon both on my FZ, I can't compromise either of those things. Can't justify re-padding the now discontinued " FZ-10 " comfort seat and don't think it possible to alter the headlight angles. I think an aftermarket upper / lower triple tree would be ideal for me. Ohlins all around are on the checklist so rear height wouldn't a problem.
mario
Post by mario on Apr 18, 2019 1:38:02 GMT -7
Having read through this thread, something I will comment on is that there is no such thing as a "clean adjustment". In raising the rear ride hight via the linkage you will have made several adjustments at once without realising.
Anti-squat will have increased, swingarm angle has increased, this has in turn reduced the wheel base, rake will have decreased, trail will have decreased, centre of gravity will have moved, these are all things you need to think about when making adjustments.
People say to adjust 1 thing at a time, but what they don't tell you is 1 adjustment will adjust 3 or 4 other things, thats why top race teams make multiple adjustments at once. They have to offset the "unwanted" changes that have occurred in order to make the 1 change they do want, so they are truely making 1 change at a time, when most people "only" adjust preload they don't think about how this affects other aspects of the bike.
So it's something to keep in mind. Another thing I would say is start with the basics, linkage changes have massive effects on the bike. Stick with the KISS principal (Keep It Simple Stupid).
First start by getting the sag set correctly, if that means you need stiffer or softer springs, do that first and foremost. Then work with the dampening adjusters, after you have a reasonable baseline, if you want more weight on the front, look at riasing the forks through the yokes (tripple clamps) or raising the rear with shimms instead of linkage changes.
Make changes that will have minimal side effects with other settings, take lots of measurements before and after and if you raise the rear and notice it has changed 3 other measurements, make adjustments to put them back to how they were while still maintaining the 1 change you want, then test the bike, in the knowledge you have literally just changed 1 thing.
Something you'll also notice is the bike might not respond at all to huge changes in some things, but will change how it handles dramatically to minor changes in other things. Again that's something you will just find with experience, but to find these things you need to ensure each change you make only alters 1 thing at a time.
It's a long process and will take a lot of effort, but it's the proper way to do it. Making changes to linkages right off the bat without even getting the sag set and without taking into account all the side effects the linkage change will create will just set you up for an even longer process with even more headaches.
micke
Post by micke on Jul 30, 2019 23:49:21 GMT -7
Rise the preload at rear and use sporty tires with egg profile for starters ? I don’t get it my Sp little rises in back is perfect handeling now . The bike is very good in chassi atleast for road . Haven’t tested on track yet
Post by Pistolpete on Jul 18, 2024 11:13:38 GMT -7
Hi im a heavy weight clocking in at 125kg and when i sit on my 2016 nt 10 the rear us very low i an almost 3/4 turns down on preload on rear shock to stiffen for my weight im considering getting 40mm shorter dog bones to jack bike up i did this on my bandit 1200 and it worked well do u think it will work on these bikes i dont have the moneyfor a rear shock upgrade but i cant find any info online of jacking rear up with og bones its seems only peopletak about loweringit any info is greatly appreciated Glad you liked the mod. Since dropping the yokes 20mm I have fitted an aftermarket shock that is length adjustable, so have raised the rear end 10mm. Have gone back to stock position on the yokes for the time being as being a heavyweight I am constantly bottoming out the forks even with max preload. Will be having a fiddle again when I get stronger springs fitted in the forks.
