bigkurka
Post by bigkurka on Nov 5, 2018 15:45:19 GMT -7
Hello everyone, so I've got my mt10 and I'm starting to ride it at faster speeds now but I get a lot of head buffeting when I'm going faster than 80 mph. I using an older shoei rf900 helmet. Anyone got any ideals on how to deal with this. I've been looking at the new shoei x14 helmets but I don't want to spend that kinda money if that's not going to really help that much.
One other thing also. when riding at high rates of speed like 100+mph the bike feels a little unstable kinda like it doesn't want to track straight or its floating side to side. I do weigh 300lbs. Is it a nature of the beast type of thing or do I need to have the suspension up for my weight?
Thanks in advance BigKurka
Post by RedAndBlack on Nov 5, 2018 15:56:19 GMT -7
I don't think a helmet is going to have as much of a change on head buffeting as a windscreen would. I would look into windscreens instead. Basically made dealing with the wind a lot easier when I got a better windscreen.
As a big guy, yes absolutely suspension and even tire pressure are going to be a big deal for you. Most sportbikes are setup for like 160 LB people.
Post by evitzee on Nov 5, 2018 16:03:21 GMT -7
Suspension should always be set up for your weight and riding style. With your weight the rear suspension is certainly being taxed, you need to tighten things up front and rear, that should help but may not settle things completely. I notice no instability at speeds of 85-100 mph, it's straight as an arrow. You might want to check the rear tire alignment, it could be off a bit. And make sure your tire pressures are in range.
Head buffeting is a personal thing, often it will bother a rider and other rider's don't feel it. If you are coming from a bike with more wind protection it will take a while to get used to the naked setup of the MT-10. I only rode it about 30 miles before I put on a Powerbronze shield and I don't notice any head buffeting wearing an HJC RPHA-10 or 11 Pro helmet. Some people like the naked look and don't want to put on a screen but a screen does quiet things down in the cockpit. I wouldn't count on a new helmet solving the problem.
peripateticmike
Post by peripateticmike on Nov 5, 2018 16:14:13 GMT -7
At 225-230lbs, I don't notice any kind high speed unsettling. I asked in your other thread, where are you in socal? I can hook you up with a really good suspension tuner if you don't want to tackle it yourself. It will only cost $50. Unless he suggests replacing components. At your weight setting sag correctly might require stiffer springs. After he set mine up, the bike feels night and day different, suspension is much stiffer than before as well.
bigkurka
Post by bigkurka on Nov 5, 2018 18:14:55 GMT -7
@peripaticmike I'm located in the north west corner of orange county. How much do you think a rear spring would run out of curiousity?
I guess I'll just have to get used to the head buffeting because I don't want a windscreen hahaha.
I'm curious what do you guys run your tire pressure at. I was really surprised when I read the manual and it said to run I think 42psi in the rear tire. I've always ran my tire pressure anywhere from 30 to 35psi on on my old gsxr and Harley.
peripateticmike
Post by peripateticmike on Nov 5, 2018 18:24:30 GMT -7
Just replied to your other thread. Here's his website www.sportbikesuspensiontuning.net He's probably about 100 miles from you. I would hit him up. As far as tire pressures, at your size I'd keep them at recommended pressures for every day riding. 36 front 42 rear.
bigkurka
Post by bigkurka on Nov 5, 2018 18:40:32 GMT -7
Thanks peripaticmike I will definitely check them out
and thanks you RedAndBlack and Evitzee I appreciate all to info and recomendations.
Post by Deleted on Nov 5, 2018 18:48:58 GMT -7
Hey Bigkurka, first of all, please define head buffeting. If you don't have any aftermarket or accessory windscreen on your FZ/MT-10, head buffeting should be non-existent. I'm afraid what you're describing is simply wind resistance. You only get head buffeting with windscreens, which is your helmet getting whipped by the wind in every direction; very annoying. That's exactly why I now chose a naked bike with no wind protection anymore. After owning dozens of bikes, I never found a windscreen without buffeting; just some worse than others. If you don't want any buffeting with a windscreen, you'd need a HUGE one... and that defeats the purpose of riding, at least for me. Of all my bikes, only my GL1800 with the windscreen all the way up didn't have any buffeting, but it was a barn door. Anyway, a very easy way to know if you have buffeting or not is to stand on the pegs. Try that. If you don't feel any difference, like I certainly don't, then you have no buffeting. Finally, with a naked bike, you have to certainly slow down compared to a faired bike, which I'm ready to do. I'm going on my first trip tomorrow, and will also play with speeds to see what is sustainable without fatigue. Just like you mentioned, should be around 80 mph, which is more than enough. I used to cruise at 100 on my previous bikes, but much rather cruise at 80 and feel faster, and don't risk getting a ticket (still have a perfect driving record). Since I'm still breaking my bike in (97 miles at the moment), won't go faster than that this time, but in the future, it'll have to be in short bursts only. And I MUCH prefer that than a freaking windscreen. My challenge tomorrow will be to get 130 miles out of a tank, or risk not making it back. Ha ha. So won't certainly speed on the way to Gila. Will take all back roads, to finish the break-in. Oh, and with your weight, you need the recommended 36/42, or something very close to it. I set mine to 33/36, but I'm 160, never a passenger, and only a small tailbag on the pillion. Good luck.
nemecham
Post by nemecham on Nov 5, 2018 20:07:01 GMT -7
When I first got my FZ, I was running an old Arai Profile helmet. I didn’t ever get any buffering, but the wind would beat the hell out of my chest when riding in some windier areas. When riding between 80-100 mph, the wind would get under my helmet and try to lift it off my head. I guess that’s what I get for being a being a bigger dude, weighing in @ 270lbs and 5’11”. I suppose replacing the cheek pads would help as well. But instead, I decided to go with the Arai Defiant, which was designed more for naked/cruiser bikes. It has a bigger chin piece that hangs lower than the profile which helps deflect the wind. Recently, I have added a Puig touring windscreen which moves the air from my chest to my chin area and still got some buffeting. I went another step and added the clip on Puig visor. Now, the wind hits at about eye level with little to no buffeting. I haven’t had the chance to take it above 80 with that particular setup and I probably won’t have a good chance until next spring. I am not crazy about the looks with the windscreen, but the extra protection is nice. I am considering pulling it off for my regular commute/rides around town, and putting it back on before longer trips to help reduce fatigue. I’ll attach a pic below. Regarding the way it drives... straight as an arrow. My first instinct would be to check the alignment of the back tire as well. I hope this helps! Neil
bigkurka
Post by bigkurka on Nov 6, 2018 19:08:20 GMT -7
Hi there elptxjc, I would describe what I'm sensation that I'm feeling is like my head is slightly bouncing side to side. No I do not have a windshield or any aftermarket screen and I don't want one do personal tastes. It's not a super bad thing it's more of an annoying thing. Also I don't feel the wind getting under my helmet and trying to lift it either. I rode a soft tail Harley for many years with open handle bars at speeds at and above 80 and never had this sensation on my head/helmet. I know on the Harley I sat lower in the saddle but the wind still hit me right in the face. This is why I was kinda thinking it could possibly be a helmet issue. I see all these different style helmets with different shapes and rudders on them and stuff. Also to throw out there I'm 6' tall.
Post by Deleted on Nov 7, 2018 0:39:30 GMT -7
Hey, I thought you were blaming the bike. Ha ha. Yeah, for higher speeds you need an aerodynamic helmet, but even an old RF900 should be fine on that department. Weird. At 6', it's definitely not the bike. Went for a long ride today for the first time (5' 10" here), and I get 100% clean air. Having said that, air is not always clean, as when you get buffeted when passing semis, for instance. I have a Shoei GT Air, and today experienced a bit of buffeting when the wind (it was windy) hit me at a certain angle on the way back, whether sitting on the bike or standing up, so even with a good helmet it's possible to sometimes get a bit of buffeting. But I changed my speed and it went away. It was nothing like the buffeting you get with a 'bad' windscreen, so not an issue for me. Only slightly annoying. I'd get a new helmet buddy. Yours is probably not that protective anymore; remember they lose protection with age, regardless of use. The good news is even cheaper helmets are as good as the premium ones now, but unfortunately, they don't fit my stupid head. Only the Arais, which I don't like, and the Shoei GT Air and the racy X series, but they're too noisy. Sold an X-11 for the GT Air, and it's a much better helmet for me, even though it lost a bit of ventilation that I like in summer, but they're just too darn noisy, even with earplugs. If you need advice on helmets, I'd go to webbikeworld.com. They have a ton of information on helmets. Good luck.
bigkurka
Post by bigkurka on Nov 7, 2018 9:13:02 GMT -7
Thank elptxjc I will definitely check that out.
Post by mrcdharwood on Nov 9, 2018 2:15:38 GMT -7
Good God that looks horrendous 🤮
harri183
Post by harri183 on Nov 9, 2018 23:20:26 GMT -7
Sounds like something is wrong, even at 130-140mph I don’t get any buffering and it’s as planted as a rock, I guess it depends what you are used to. I had a cross tourer that did what you describe and it was horrendous your vision would go so you could not see because of the head movement just horrible from a bike that is built as a tourer. it turned out to be air pressure coming up around the forks and screen took the screen of and no problems just bad design and depending on the height of the rider if you hit the sweet spot then you were in for a crap ride. I know it is a simple one but have you checked Tyre pressure for the vague feeling?
fastback89
Post by fastback89 on Nov 11, 2018 15:17:26 GMT -7
I am using an X14 helmet. It is hands down the best helmet ever for buffeting, I highly recommend getting this helmet. My bike is all stock and I feel nothing.
Post by Deleted on Nov 11, 2018 22:30:34 GMT -7
Yeah, racing helmets will always be the best... if you can stand the noise. The main reason for that is they're designed to also be aerodynamic when rotating your head, which is not the case on most others. Or at least at a lesser degree. And THAT is the reason 'lesser' helmets might buffet a little with strong side winds. I really like my Shoei GT. Haven't ridden this bike above 95 or so due to break-in, but without strong side winds, it's super stable and very quiet compared to my ex-X12. And only very mildly annoying with strong headwinds, like I experienced on my last trip, and only above 80, so not a big deal at all. It was waaaay worse with windscreens, so not pleasant in any condition, really. I have to mention something more about aerodynamics of a helmet: You have to have your head in the proper position for it to be effective, and you can easily test that by moving your head up and down, and feeling/hearing the difference. If you're holding your head more upright than normal, then helmet is not going to work the same. Worth checking that out too. Like I mentioned before, the best test to make sure you have no part of the bike that is contributing to buffeting is to stand on the pegs, where you for sure will have clean air. Yamaha did a great job with that micro fairing, making sure no turbulent air would come out of hitting headlights, and other parts in front, to your head/neck. So basically if your bike is stock, your problem is with your helmet, period. Finally, looks like Fastback89 also misinterpreted the OP, like I did. He wasn't complaining about the bike, but his helmet.
tbloyd
Post by tbloyd on May 9, 2021 17:45:41 GMT -7
i got a new 21 mt 10 put the Madstad 24 inch windsreen on and got wind buffetting noise above my forehead .got a new shoei rf 1400 lid . it helped very little ,took the screen back off ,bamm, the buffeting noise is gone . i get a consistent wind noise that is a lot more quiet and tolerable . im 6 ft 3 inches 230 lbs . did more research and found any wind sreen on the mt 10 will create head buffeting on a taller rider . i do get wind in the chest but its more tolerable than the anoying head buffeting. i put shad hard bags on it ,there awsome. now if only that hard seat would breakin, other than the bike is excellent . anyone want to buy a madstad 24 inch windscreen with 150 miles on it
redlinez
Post by redlinez on May 10, 2021 12:55:23 GMT -7
That is one of the few helmets that fits my long oval xxl head pretty good. It just doesn't have a drop down visor or self tinting shield. I will try the GT Air next when I can find a xxl.
tbloyd
Post by tbloyd on May 10, 2021 14:18:26 GMT -7
oh but they do shoei just introduced thier transitions full face shield .lite in the dark and dark in the sun a must have
redlinez
Post by redlinez on May 10, 2021 14:21:11 GMT -7
Man, that adds about $200-250! Bell Star has one as well, I may have to try them on again. They are just really hard to open the shield. Practically pulled the helmet off my head trying to open it. I also liked the feel and fit of the LS2 Challenger carbon fiber.
