Post by Deleted on Oct 24, 2018 18:26:31 GMT -7
Like many here, I like to strive for perfection when it comes to my vehicles, and would like to check my chain alignment. And it'd be just once, since I'd mark the swingarm after that, and wouldn't need it ever again. That's why I refuse to buy an expensive laser unit, but they're the best. If somebody wanted to rent one, it'd be awesome. But since that's unlikely, I want to buy a cheap but effective one, like the MotionPro. However, I doubt it'd fit our bike, since the top chain guard requires wheel removal to take it out, and with that weird protective ring don't think the typical chain tools would fit at the bottom of the sprocket. And that's precisely the reason for this thread. If you have a chain tool that works, please post details so others and myself can order it knowing it'd work. Many thanks. JC
morbo
Post by morbo on Oct 25, 2018 6:42:54 GMT -7
I have the MotionPro and I am able to fit it under the chain guard... barely. It's not ideal and a bit of a PITA, but I'm too lazy to mess with removing the guard. I can try and snap a photo tonight if you are curious.
Post by Deleted on Oct 26, 2018 0:04:36 GMT -7
superspirit
Post by superspirit on Oct 26, 2018 4:12:33 GMT -7
That's the tool I use, works well. I use it on all 4 of the bikes in my garage.
morbo
Post by morbo on Oct 26, 2018 5:40:05 GMT -7
Yup, that's the one I own. I'll try and get a pic today, otherwise it might be a few days. Once it's on there, it's solid. I just installed some Lightech chain adjusters so alignment isn't as much of a worry but they're definitely not for budget-minded individual.
morbo
Post by morbo on Oct 29, 2018 19:08:05 GMT -7
Here you go.... It fits on just fine under the chain guard and the guard itself is flimsy enough to pull to the side to check alignment. Hope this helps.
Post by Deleted on Oct 30, 2018 10:34:57 GMT -7
Thanks for the picture. You had to bend that thing pretty badly; that's what I was trying to avoid. At least I know it can be done, but I'll try from the bottom first. Thanks again.
Post by clayton on Oct 30, 2018 13:45:52 GMT -7
Took my belt guard off. Cleaner look for sure.
peripateticmike
Post by peripateticmike on Oct 30, 2018 16:00:11 GMT -7
Took my belt guard off. Cleaner look for sure. Ditto
Post by Deleted on Oct 31, 2018 11:39:40 GMT -7
Took my belt guard off. Cleaner look for sure. Hey, no extra mess with the chain exposed? Noticed the end of the guard was full of crud (about the last inch), but the rest of the guard seems useless indeed. But you had to remove the freaking wheel to remove it, right? I see no way to remove that hex bolt right next to the chain. Hopefully there's a way. He he. Since I'm not going to lube my chain the normal way (by spraying it directly), I'm probably going to remove it too, especially if no need to remove the rear wheel. Otherwise, might wait until a tire change. Will lube the chain by spraying a rag and then putting it on the chain, to avoid any excess, which is what flings out. Thx.
Post by clayton on Oct 31, 2018 12:05:27 GMT -7
Took my belt guard off. Cleaner look for sure. Hey, no extra mess with the chain exposed? Noticed the end of the guard was full of crud (about the last inch), but the rest of the guard seems useless indeed. But you had to remove the freaking wheel to remove it, right? I see no way to remove that hex bolt right next to the chain. Hopefully there's a way. He he. Since I'm not going to lube my chain the normal way (by spraying it directly), I'm probably going to remove it too, especially if no need to remove the rear wheel. Otherwise, might wait until a tire change. Will lube the chain by spraying a rag and then putting it on the chain, to avoid any excess, which is what flings out. Thx. No mess with the guard removed. I’m using that DuPont Stuff that doesn’t sling off. I posted a pic of the can in another thread here. I removed mine with the wheel still on. Used a regular metric L shaped Allen wrench. It was hard to turn cause yamaha uses red loctite on it.
xroadracer
Post by xroadracer on Jul 19, 2021 11:24:02 GMT -7
Took my belt guard off. Cleaner look for sure. Hey Clayton. Do you have a pic of the swingarm with the chain guard off. I'm considering pulling the wheel to get at that one bolt. As you know the guard is taped to the swingarm and I wanted to see what it looks like removed. Thanks! -Mike
Post by clayton on Jul 19, 2021 14:40:02 GMT -7
xroadracer
Post by xroadracer on Jul 20, 2021 11:22:21 GMT -7
Thank you very much for the pic. Since I haven't pulled the rear wheel yet to see how it's put together, it seems you cut the rear part of the chain guard.
Post by parthz8 on Jul 20, 2021 16:38:17 GMT -7
Hey Clayton. Do you have a pic of the swingarm with the chain guard off. I'm considering pulling the wheel to get at that one bolt. As you know the guard is taped to the swingarm and I wanted to see what it looks like removed. Thanks! -Mike Hi clayton, your chain looks so clean and maintained...it is the new one? or how do you clean/maintain it so well? What you use to lubricate? So it does not fly everywhere without the chain guard
Post by clayton on Jul 22, 2021 5:25:37 GMT -7
Hi clayton, your chain looks so clean and maintained...it is the new one? or how do you clean/maintain it so well? What you use to lubricate? So it does not fly everywhere without the chain guard This is what I use to clean and lube my chain a couple times a month. The Tirox is no longer available so I started using the DuPont. Iv got 12,500 miles on my chain now.
Post by sdshawn on Jul 22, 2021 6:51:18 GMT -7
Motion pro chain alignment, purple power degreaser, amsoil chain lube .
Post by willl84 on Jul 23, 2021 5:33:25 GMT -7
Hi clayton, your chain looks so clean and maintained...it is the new one? or how do you clean/maintain it so well? What you use to lubricate? So it does not fly everywhere without the chain guard This is what I use to clean and lube my chain a couple times a month. The Tirox is no longer available so I started using the DuPont. Iv got 12,500 miles on my chain now. Bel Ray Super Clean is the only stuff I've used that doesn't fling off all over the place. Came across that stuff when I had my TLR with white wheels.
