Post by Deleted on Oct 22, 2018 17:10:40 GMT -7
Hey gang, just got my Trackside front chock (very well made, by the way), and after assemblying it, and adjusting it to have zero play (required just 1 washer), its first job was to check oil level. I knew it was overfilled, with the entire window filled with oil, but didn't know how much. Anyway, the first part of that job is to make sure bike is perfectly vertical; I used a level with a magnet attached to one of the front rotors. Oil was covering the entire window but barely, so about 1/4-qt overfilled, or thereabouts. Bike has only 38 miles, so don't think there's any damage done, since it's not way overfilled, but should I open the drain plug a little, and drain until level is at the max mark? Or no big deal and leave it alone? Thank you in advance for your help. JC
bigweb2001
Post by bigweb2001 on Oct 22, 2018 19:39:40 GMT -7
Yes, I would just put a container under it and loosen the drain bolt to bring it down. No biggie on effort, saves peace of mind...
Post by evitzee on Oct 22, 2018 22:38:13 GMT -7
Personally, I'd leave it alone, it's not dramatically overfilled and you are going to change it at 600 miles anyway.
Post by RedAndBlack on Oct 23, 2018 11:56:18 GMT -7
I wouldn't go off the measurement on the chock. The chock raises the front end and would raise the oil level in the reservoir up on the end that the measurement window is. Go off the measurement with the bike on flat ground and upright.
If you're still worried about it, you can stick a straw into the reservoir and cap it with your thumb then remove and keep doing that until you think you have removed enough. A cloth towel could work to suck some of the excess oil up.
Post by Deleted on Oct 23, 2018 14:25:21 GMT -7
Hey guys. The last post I saw was Bigweb2001's, and I followed his advice... and glad I did, since about 1/3rd of a quart came out with level at top mark. I also took the opportunity to replace the stock drain plug with the GoldPlug I had ready for the 600-mile oil change. Tried to let excess oil drip out of the drain plug, but nothing came out until plug was out, so decided to change it. And no, with the front tire 1" off the ground, it basically makes no difference on the level, especially if you only fill to the lower (rear) of the 2 marks. Anyway, don't think the level was high enough for the crankshaft to hit the oil, and turn it into froth. But maybe enough to get some oil into the airbox. Won't know until I change the filter, but with only 38 miles, I agree there should be zero issues. Another thing is you cannot insert an oil extractor tube (or anything else, for that matter) from the oil cap to the sump folks, so draining from the drain plug is the only way to lower oil level. Finally, the only thing I didn't like about the GoldPlug magnetic drain plug is it protrudes a little below the headers, but it's still higher than the muffler/cat, so not a big deal. Thanks for all the input folks; greatly appreciated.
Post by Deleted on Feb 5, 2019 10:55:46 GMT -7
Hey gang, just wanted to emphasize the need to make sure bike is perfectly vertical if you want to accurately measure oil consumption, or if you want to top oil level to the max, like I always do. As I said on my first post, easiest way is to put a level against the front part of one of the front rotors. Even with the bubble touching one of the centering lines (in theory still considered level), oil level at the window varies quite a bit. So I make sure bubble is right at the middle. That way, if you ever experience any oil loss, you'd know exactly how much. By the way, just changed the factory oil with Castrol Power1 4T 5/40 at 497 miles (4.4 qts), and there was some metal dust on the magnetic drain plug, so a nice addition IMO. Hope this helps.
pokeimam
Post by pokeimam on Mar 18, 2019 3:59:11 GMT -7
Start the motor , if oil level drops to a place where you can see it in the glass , its OK .. A little bit more oil doesn't harm your engine . Factory recomendation is 10w40 - 15w50 . Anything between them could be used as 10w50 . Be use to use full synthetic.
guitarian
Post by guitarian on Jun 3, 2019 4:48:37 GMT -7
Start the motor , if oil level drops to a place where you can see it in the glass , its OK .. A little bit more oil doesn't harm your engine . Factory recomendation is 10w40 - 15w50 . Anything between them could be used as 10w50 . Be use to use full synthetic. How much is "a little bit more"? My dealer did the 600 mile (570 actually) oil change. I should have checked it before I left the dealer, but I rode about 300 miles and checked it at home. When level, oil completely covers the sight glass. I tried to siphon some out but I could never reach the actual oil. My plastic tube had a permanent coil and was too curvy to get in there. I'm pretty sure the tech just did a quick drain leaving some oil in the reservoir and then added x quarts of oil without checking the level. That's why I always try to do it myself.
lotust251
Post by lotust251 on Jun 3, 2019 12:47:57 GMT -7
I went with what the local dealer had in stock Yamalube 15w50, yeah just loosen that 6mm (I think ) drain and let the main vain drain for 1 second. I would do it cold so it comes out slower
Post by clayton on Jun 3, 2019 15:05:03 GMT -7
I went with what the local dealer had in stock Yamalube 15w50, yeah just loosen that 6mm (I think ) drain and let the main vain drain for 1 second. I would do it cold so it comes out slower You wanna drain the oil when it’s warm to hot so it drains out better and and all particles are suspended in the warm oil. I let mine drain for 15-30mins
Post by Deleted on Jun 13, 2019 18:38:43 GMT -7
When level, oil completely covers the sight glass. I tried to siphon some out but I could never reach the actual oil. My bike was like yours. You need to loosen/remove the drain plug. That's what I did. I took the opportunity to install a magnetic drain plug. With all the sight glass full of oil, it'd still be way above max when you do the plug swap, so don't worry about draining more than needed. And if you don't want to replace the plug, it'd be less mess... but you run the risk of a small leak by leaving the same crush washer. Or risk stripping theads by overtorquing. Therefore, what I'd do is replace the crush washer while you plug the hole with a thumb, and somebody helps you replacing it. As for the rest of the oil, just let oil flow slowly over your (latex gloved) hand to a reservoir, until at the right level. I don't remember exactly how much I removed, but I was glad I did it, since it was more than I thought. I rode about 300 miles like that, until I got my Abba stands, to be able to drain it. Stupid dealer couldn't even check oil level properly; frustrating. By the way, I used a magnetic level attached to a front rotor to make sure bike was perfectly vertical, before draining oil; even a bit of angle makes a big difference in oil level window. And same when checking oil level, to more accurately monitor oil consumption. Hope this helps.
guitarian
Post by guitarian on Jun 15, 2019 10:38:50 GMT -7
As for the rest of the oil, just let oil flow slowly over your (latex gloved) hand to a reservoir, until at the right level. I don't remember exactly how much I removed, but I was glad I did it, since it was more than I thought. I rode about 300 miles like that, until I got my Abba stands, to be able to drain it. Stupid dealer couldn't even check oil level properly; frustrating. By the way, I used a magnetic level attached to a front rotor to make sure bike was perfectly vertical, before draining oil; even a bit of angle makes a big difference in oil level window. And same when checking oil level, to more accurately monitor oil consumption. Hope this helps. Nothing like the feel of warm oil flowing slowly over latex. I did the same thing. I measured the extra oil using my "precision graduated cylinders" and ended up with .29 quart. Probably did no damage but why couldn't the damn tech take 2 minutes to top it off correctly instead of just pouring in what the book says. It leads me to believe that he also didn't let it drain enough old oil first. Thanks for the reply!
