narcissus
Post by narcissus on Oct 8, 2018 7:17:51 GMT -7
When I turn the ignition on all the lights on the instrument panel come on momentarily like they're meant to and then turn off but the oil pressure/coolant temperature warning light remains on. When I start the engine the warning light goes off. The owner's manual states:
Like I said mine remains solid and doesn't go off briefly like the manual states it should, but does go off when the engine starts.
I can also hear the high pitched whine the bike makes when you first turn the ignition on which usually stops after a second or so, but the whining noise remains constant until I start the engine.
The bike is only a few months old and only has 500 km on it.
Should I just refrain from riding and take it to my local Yamaha dealer?
scuba77
Post by scuba77 on Oct 8, 2018 7:44:50 GMT -7
The oil light will stay on since there is no oil pressure till the bike is started. As far as the whine, it's probably the electronic fuel pump, you just don't hear it when the engine is running.
If you are worried, call the dealer first and talk to their service person then decide whether to take it to them or just ride..
narcissus
Post by narcissus on Oct 8, 2018 7:52:36 GMT -7
Shouldn't it flash first like the manual states? Also unless I'm going crazy I'm sure it wasn't there before.
scuba77
Post by scuba77 on Oct 8, 2018 10:48:50 GMT -7
If you're worried, give Yamaha a call. They may have changed the electronics without updating the manual or....
Post by Deleted on Oct 8, 2018 15:26:52 GMT -7
I haven't checked that the dash lights do that, to be honest. I just check that they don't stay on after starting the engine. On this bike, the ABS light will stay on until rolling a few feet, but all others should be off. As far as the fuel pump, it should only prime for a second or so and shut off until engine is started. If it keeps running, and it didn't do that before, then you might have an issue, like a check valve, bad fuel pressure sensor, or something else. Did you just buy the bike, or it started doing that later? Good luck.
Post by RedAndBlack on Oct 8, 2018 20:47:14 GMT -7
Yea I wouldn't be concerned. That light stays on when there's a problem. When it's off, I think it's safe to say it's fine.
narcissus
Post by narcissus on Oct 9, 2018 6:33:49 GMT -7
I rang the bike shop today, they said the worry is the fact that the fuel pump is continuously making the noise upon turning the ignition on and said not to ride it for now. One of their senior mechanics is going to get back to me.
What's shit is the fact that my closest Yamaha dealer is 300k away so I can't just drop in and have them have a look, and if the mechanic gets back to me and tells me I need to bring it in then I can't ride all that way without risking damaging the bike.
Post by evitzee on Oct 9, 2018 7:34:46 GMT -7
In the meantime why don't you disconnect the battery cable for about 30 minutes. Perhaps the system just needs a hard reset. Then try again and see if the fuel pump still continues to run constantly.
narcissus
Post by narcissus on Oct 9, 2018 15:25:05 GMT -7
Good idea mate thanks, will give that a go.
narcissus
Post by narcissus on Oct 9, 2018 16:30:00 GMT -7
Didn't work unfortunately.
Post by Deleted on Oct 9, 2018 18:11:45 GMT -7
Sorry to hear. I haven't studied the fuel system on this bike, but I suspect it's a returnless system. If so, my first suspect would be a bad fuel pressure sensor. But it could also be an ECU issue, where it activates the pump a second or so to assure a quick starting. A bad check valve would probably cut the pump and activate it again when pressure drops. I don't know, but it really sucks that we can't know without a freaking dealer. I wonder if the ECU threw a soft code. Is there a way to retrieve Yamaha codes from this bike? I want to be able to read ALL codes, and also to erase them, and monitor other parameters if needed, like with VCDS for Audi/VWs, and FORScan for Fords. Without any computer help, we're sitting ducks, and you have no choice but to take it to a dealer. Sorry to hear that. Oh, and rather than risk getting stranded somewhere, or get the bike damaged by roadside assistance, I'd rent a U-Haul motorcycle trailer ($15/day), and take it in. Please keep us posted, and good luck.
Post by evitzee on Oct 10, 2018 13:49:11 GMT -7
I went for a ride today, once the ignition goes through it's pre-start cycle three lights remain on and solid: Oil, Neutral, ABS. I suspect the OP has no problem with his bike. Ride it, if it has a fueling issue it will eventually let you know. I don't think you actually have any issues.
Post by Deleted on Oct 10, 2018 16:13:58 GMT -7
While I was activating the QS yesterday, also watched the lights, and none extinguished and came back again. Just like Evitzee, all turned on, and then extinguished, except the 3 mentioned by him, which always stayed on. So no issues as far as lights indeed. However, my fuel pump turned off after priming for a second or so. THAT is where the OP has an issue, I think. My main worry would be that the fuel pressure regulator is working properly. With the pump on constantly, fuel pressure could be a lot higher than it needs to be. As far as the pump, my guess is it's working constantly when riding, so that in itself it's not a huge issue IMO. But I'd like to know what's going on in there.
narcissus
Post by narcissus on Oct 31, 2018 4:36:18 GMT -7
Update: Got the bike back from the shop. Apparently a rock had hit a sensor on the front wheel triggering an ABS fault light. When I told the mechanic that according to the manual it was the oil pressure and coolant temperature warning light he seemed a bit confused. Either way it's fixed now.
Also got them to install my Givi sports screen. Rode 300km with it today. Really liking it. Doesn't completely block out the flow of air obviously but notably reduces and buffers it. Works better than I expected for such a small screen and really fits the lines of the bike.
Post by Deleted on Oct 31, 2018 11:41:45 GMT -7
Pic?
narcissus
Post by narcissus on Nov 1, 2018 0:00:05 GMT -7
