Hi All. Wanted to share my FZ 10 build.
Full list of mods below.
1. Woodcraft Front Axle Slider Kit
2. Woodcraft Rear Axle Slider Kit
3. Woodcraft Frame Slider Kit - mounts and pucks
4. Woodcraft engine covers (left and right)
5. Woodcraft rear sets
6. RhinoMoto Bar End Mirror Mounts
7. CRG Hindsight Lanesplitter Bar End Mirrors (left and right)
8. TechSpec XLine Tank Pads
9. Yamaha GYTR comfort seat
10. Vortex V3 Fuel Cap
11. Evotech Performance Radiator + Oil Cooler Guard
12. Vagabond Motorsports Fender Eliminator
13. Scorpion de-cat link pipe
14. Scorpion serket taper slip on - carbon fiber
15. Yamaha GYTR quick shifter
16. Ohlins steering damper SD 047 – For some reason Ohlins won’t confirm it’s compatible with the FZ/MT 10 as it’s listed as only being compatible with 15+ YZF-R1, but it definitely is. A number of aftermarket R1 parts are of course compatible with this bike.
17. 520 Chain conversion:
a. Gold DID 520 ZVMX chain
b. Supersprox front and rear sprocket
c. Driven Rear Sproket Nuts – Black
18. Brake Mods:
a. Galfer wave rotors – front and rear
b. Spiegler Stainless Steel Brake Lines front and rear w/ red aluminum banjo bolts – line color - Translucent Smoke; fitting color - red
c. Yamaha 2015+ R1 Nissin radial master cylinder
d. Brembo brake fluid reservoir kit for radial master cylinder
e. Galfer Brake Pads – front - HH Sintered Ceramic; rear - HH Sintered
19. Carrozzeria V-Track Forged Aluminum Wheels - satin shot peen black anodized
20. Dunlop Sportmax Q3+ Front and Rear Tires
21. ASV F3 brake levers – clutch side - standard length; brake side - shorty length - compatible with R1 master cylinder
22. Graves Smog Block Off Plates – Removed complete AIS
23. BMC Air Filter – Race
24. Antigravity YTZ10 Lithium Nanophosphate Battery
25. Lightech Chain Adjusters Yamaha YZF-R1 15-18 - Black
26. ECU Flash
27. Pending - Just ordered FTECU autoblipper. Should have that installed soon. Anyone interested in the Yamaha GYTR quick shifter let me know.
