wozfromoz
Riding is a way of life
Post by wozfromoz on Sept 20, 2016 14:05:11 GMT -7
When I changed bikes to a MT-10 from the Fatbob I found in the test ride the MT-10 gave me the same kick in the pants that a well set up Harley gives. The upright riding position, the aggressive straight out the corner rush. My new MT-10 is so much more to experience, with so much more power, brakes and handling. All can be done so much faster, it's insane how much bike you get at an entry level price. On a tight, bumpy, opposite camber circuit's the MT-10's suspension works fine for me, the A mode or Standard works a treat and I'm starting to use TCS 1 rather than 2 which seems to be better. Both bikes engaged me the same way through this type these type of corners and the MT-10 cracks it hard through everything else as well. So I hope you enjoy your new MT-10 as much as I am.
Post by Cruizin on Sept 20, 2016 14:14:01 GMT -7
When I changed bikes to a MT-10 from the Fatbob I found in the test ride the MT-10 gave me the same kick in the pants that a well set up Harley gives. The upright riding position, the aggressive straight out the corner rush. My new MT-10 is so much more to experience, with so much more power, brakes and handling. All can be done so much faster, it's insane how much bike you get at an entry level price. On a tight, bumpy, opposite camber circuit's the MT-10's suspension works fine for me, the A mode or Standard works a treat and I'm starting to use TCS 1 rather than 2 which seems to be better. Both bikes engaged me the same way through this type these type of corners and the MT-10 cracks it hard through everything else as well. So I hope you enjoy your new MT-10 as much as I am. Your not gonna mount a screamin eagle exhaust on that are you? lol, just flippin you crap! Thanks for the video!
wozfromoz
Post by wozfromoz on Sept 20, 2016 15:27:44 GMT -7
Yes, the pipes are pretty loud on the Fatbob, I've been very tempted to make the MT louder, noise is good but not the fines for excessive noise.
