nmerique
Post by nmerique on Aug 12, 2018 19:16:03 GMT -7
My brake shoes seized on a ride yesterday and basically melted my shoes and destroyed my caliper. Does anyone know if the rear caliper on a R1s/ R1m will work on a Fz10? I know the part numbers are different but both look exactly the same, have the same bolt holes and design. I believe the only difference is the piston. There is a bunch on Ebay and I'm trying to get my bike fixed. Any help would be greatly appreciated.
Post by RedAndBlack on Aug 12, 2018 19:38:48 GMT -7
Might be the rotor difference. I think that's what it is on the front wheels but don't quote me on that.
nmerique
Post by nmerique on Aug 13, 2018 5:02:03 GMT -7
What's interesting is the r1s uses the same rotor disc as a Fz-10 on the rear wheel. I figured that since an r1s has traction control as well, I could use a caliper from a r1s because they are alot cheaper and look identical. I believe the piston is a different size but as long as you had the right shoes I dont see that being an issue. Can anyone weigh in on this?
srosa
Post by srosa on Aug 13, 2018 12:49:28 GMT -7
The R1 caliper carrier is different so a r1 rear caliper will not fit your fz10. I purchased a fixed rear caliper kit for an r1 and it was not compatible due to this difference. The rotor is the same on both bikes.
nmerique
Post by nmerique on Aug 13, 2018 14:47:15 GMT -7
The R1 caliper carrier is different so a r1 rear caliper will not fit your fz10. I purchased a fixed rear caliper kit for an r1 and it was not compatible due to this difference. The rotor is the same on both bikes. Is there any caliper grom another Yamaha bike that would work? Where can I find another caliper that isn't $200?
srosa
Post by srosa on Aug 13, 2018 15:42:16 GMT -7
The R1 caliper carrier is different so a r1 rear caliper will not fit your fz10. I purchased a fixed rear caliper kit for an r1 and it was not compatible due to this difference. The rotor is the same on both bikes. Is there any caliper grom another Yamaha bike that would work? Where can I find another caliper that isn't $200? I doubt it. A quick search of the part number only brings back references to an mt/fz10. Your other possibility might be to buy a used r1 caliper carrier to go with a used r1 rear caliper. There could be brake line or abs sensor issues to deal with so that’s something to check out. I can verify that the r1 caliper carrier has the same exact spacer thickness as the fz10 so that won’t be a problem. Honestly if it were me, I’d buy a new fz10 caliper with a used rotor and and go for a ride.
nmerique
Post by nmerique on Aug 14, 2018 7:31:48 GMT -7
Is there any caliper grom another Yamaha bike that would work? Where can I find another caliper that isn't $200? I doubt it. A quick search of the part number only brings back references to an mt/fz10. Your other possibility might be to buy a used r1 caliper carrier to go with a used r1 rear caliper. There could be brake line or abs sensor issues to deal with so that’s something to check out. I can verify that the r1 caliper carrier has the same exact spacer thickness as the fz10 so that won’t be a problem. Honestly if it were me, I’d buy a new fz10 caliper with a used rotor and and go for a ride. What years of the r1 are you talking about... 09-14? Is there any other bike that uses caliper B67-2580W-00-00?
srosa
Post by srosa on Aug 14, 2018 8:20:45 GMT -7
2015+
nmerique
Post by nmerique on Aug 14, 2018 15:35:02 GMT -7
I just got off the phone with my old mechanic....he says they only used that model caliper on the FZ-10. He can get me one for $200 take three or four days to get it in. I dont have a choice. Yamaha is a fucking joke to me now....they had to use a caliper that is on no other bike in production by yamaha....I am not pleased that Yamaha did not use the caliper from the R1M/S......would be $40 on Ebay versus $200. I am so done with Yamaha customer service. They are a joke.
