Timbo
Post by Timbo on Sept 16, 2016 19:52:55 GMT -7
Graves cat eliminator exhaust. I got my graves exhaust installed. Build quality is excellent! Sound is awesome. Comes with an insert. It is just a little louder than stock with insert, but a lot better sound. I like the insert out. Sounds awesome, nice low rumble. And it runs great! Love it!
biojester
Post by biojester on Sept 17, 2016 14:41:03 GMT -7
Looks good. What happens to the valve wiring?
Timbo
Post by Timbo on Sept 17, 2016 15:19:19 GMT -7
If you are talking about the exup valve, you remove the cables at both ends. I also removed the servo under the seat. You can leave the servo plugged in and under the seat and it won't throw a code.
Post by Cruizin on Sept 17, 2016 15:57:09 GMT -7
If you are talking about the exup valve, you remove the cables at both ends. I also removed the servo under the seat. Might make a good tech tip for ur tech tip section. If anyone else is chnaging exhaust, please take a few pics while doing so and post up a quick tech tip so thousands of others can learn from you over the years.
