revolvingrain
Post by revolvingrain on Jun 30, 2018 23:18:21 GMT -7
I would Love to have a hydraulic clutch for my FZ-10 but I can't find anything for it nor for an R1. Anyone know anything that would work? I was thinking of jerry rigging a hydraulic clutch system from another bike that i think would work; FZ-09. I think it would work so long as the cable lengths are the same. What are your guys thoughts?
scuba77
Post by scuba77 on Jul 1, 2018 6:39:51 GMT -7
I've had both on different bikes and both work well. The only advantage I saw with the hydraulic clutch is it just didn't need adjusting where it only takes a couple of minutes of your time to do a click or two on your cable. Both types can break so that's my two cents.
mrhix
Post by mrhix on Jul 1, 2018 6:49:57 GMT -7
The complicated bit would be matching the hydraulic clutch actuator movement to the bike's clutch arm movement for the correct movement of the clutch arm and feel at the lever. The hydraulic clutch manufacturer should be able to help there.
Good luck,
MrHix
eyeofmaat
Post by eyeofmaat on Jul 1, 2018 19:10:23 GMT -7
I seen a guy on the Facebook group try it. The switch gear was too big and he couldn't pull the lever in. Either swap the lever or switchgear would help. I think it was a brembo unit.
revolvingrain
Post by revolvingrain on Jul 2, 2018 11:38:45 GMT -7
Thanks for the input guys, if I find something that works I'll make sure to get back to you
mrhix
Post by mrhix on Jul 2, 2018 13:09:52 GMT -7
revolvingrain,
What are you trying to accomplish with the swap: easier pull, wider gap between pulled in and engaged, or just getting a hydraulic system?
MrHix
Post by Deleted on Jul 2, 2018 18:53:15 GMT -7
Deleted.
revolvingrain
Post by revolvingrain on Jul 2, 2018 22:34:29 GMT -7
revolvingrain, What are you trying to accomplish with the swap: easier pull, wider gap between pulled in and engaged, or just getting a hydraulic system? MrHix I've just always wanted one and want to experience it for myself; also for the very little maintenance.
mrhix
Post by mrhix on Jul 3, 2018 4:57:47 GMT -7
Yes,
They are nice. Good feel and self adjusting.
Cheers,
MrHix
