chewy1abbey
Post by chewy1abbey on Jun 11, 2018 2:36:12 GMT -7
Looking for suggestions on upgrades I have a comfort seat Looking for some performance goodies but I don't wanna void my warranty or extended warranty
griever
Post by griever on Jun 11, 2018 12:24:39 GMT -7
I'd say - Tuned suspension, Quick-shifter and ECU Flash. I don't believe the flash voids your warranty, but don't quote me on that.
iwasatoad
Post by iwasatoad on Jun 13, 2018 1:42:51 GMT -7
unsure of void or not but... air filter, mid pipe, QS and ECU flash. Those would be good places to start though doing all at once would be best. Cosmetic wise Tidy tail and intigrated tail light. I did all but the ECU flash though that is happening soon. different mirrors is on my list as well cant see past my arms with out braking a move void and or sketchy items Xup valve removal / servo buddy / fuel management PCV or Fi tec after that would be ASI removal after that sprocket change for longer gearing. for sure void items after that would be cam's after that well............. Extreme creations turbo kit. do all that thinking around 220-250 whp weather and alt pending. all are on my list to do once the coverage is gone. hope that gives you some insight into what one can do for power adding. if i manage to get all that done only thing i might do after that would be to change transmission internals to R1 internals for the higher base ratios have not dug much into if this is true or if the sprockets are just different to make the gearing longer.
loading
Post by loading on Jun 14, 2018 4:42:30 GMT -7
Hey Chewy, welcome to the forum. I'm also from WI. Do you recommend the comfort seat?
Also, does anyone know what the warranty length is? I'm only going to be able to hold off on the ECU flash for so long.
Thanks,
fzed10
Post by fzed10 on Jun 14, 2018 16:54:37 GMT -7
Some great riding up there in Wisconsin. I have ridden along the Mississippi and in the area around Reedsburg. Been to the Slimey Crud run a couple times.
