mtntrails
Post by mtntrails on May 15, 2018 2:26:50 GMT -7
This subject was brought up on the ADVRider thread and it got me thinking...
I wouldn't mind a 1" - 1.5" drop as long as the bend stayed pretty much the same. As comfy as OEM is, it's a bit too upright especially running naked.
What brand & spec spec are you running and how do you like it?
operationfz
Post by operationfz on May 15, 2018 15:58:41 GMT -7
I wrote up a thread about my Rizoma bars, LOVE them.
operationfz
Post by operationfz on May 15, 2018 16:01:43 GMT -7
decreasingdave
Post by decreasingdave on Jul 6, 2018 0:10:41 GMT -7
I kept my stock bars but flipped my mounts around.
They are offset to the rear as they come from the factory. The difference is only about 5mm but for me, it made all the difference in the world. I instantly felt more comfortable. Just that little bit of extra forward lean.
Dave
n3rd
Post by n3rd on Jul 27, 2018 14:07:26 GMT -7
I kept my stock bars but flipped my mounts around. They are offset to the rear as they come from the factory. The difference is only about 5mm but for me, it made all the difference in the world. I instantly felt more comfortable. Just that little bit of extra forward lean. Dave Have pictures? Seems like an easy quick mod to do if you're wanting it just a tad lower (like me)..
decreasingdave
Post by decreasingdave on Jul 28, 2018 13:05:10 GMT -7
There isn't really much to see. They look stock. You take the top part of the clamps off, take the handlebars out, loosen the bottom bolt enough to rotate the bottom clamp 180°, tighten them back down again and reverse the disassembly to reassemble. But here's a pic Dave
rj
Post by rj on Mar 18, 2019 22:52:04 GMT -7
Did you have to adjust anything else like cables? I'd like a little more lean over the bars and this seems like an easy thing to try.
Post by Deleted on Mar 19, 2019 10:15:46 GMT -7
If you're moving the handlebars forward and/or lower, no need to worry about cables. It's only when you raise them or add pull-back.
jaimehellcat
Post by jaimehellcat on Apr 10, 2019 8:36:49 GMT -7
This link rules, I was going crazy looking for lower bars... The angle and height is exactly what I am aiming for. Why it wasn't sold like this from the start is beyond me. Thanks for the work, research, and post.
aavmann
Post by aavmann on Apr 14, 2019 19:41:36 GMT -7
I kept my stock bars but flipped my mounts around. They are offset to the rear as they come from the factory. The difference is only about 5mm but for me, it made all the difference in the world. I instantly felt more comfortable. Just that little bit of extra forward lean. Dave Hey everyone.... I did the handlebar mount flip too. It is a subtle change but did move the bars away as described. As far as the ease of this? I found a few things that were a little difficult. Hopefully my experience will help others should that do this change. The nut that you need to loosen under the triple clamp is difficult to get to. It is a 14mm socket and after trying several different sockets and drives , I found that you need to turn the steering all the way in each direction to get to the nut. I needed to use a universal joint and several long extension pieces to be able to loosen due to several bike parts in the way. And the nut on the right side could only be accessed but taking the little clamp off of the throttle cables close to the center of the tank and getting the socket with u joint in behind. You will see what I mean once you start. The bars themselves, I used a frame above the bike and suspended the bar with he controls with adjustable straps. Other wise it will flop and bang around. . Lastly. Make sure you thread the nuts back on loosely..... then tighten the bars, then tighten the nuts, then loosen the bars and rotate to exactly where you want them. Not doing so could potentially have the relationship between the U shapes and the two mouts to not be lined up correctly. Securing the bar tightly will automatically line up the rotational orientation before tightening the bottom nuts. Make sense? I have not ridden with the change as it has been pouring rain all day but It definetely feels a little different when I sit on the bike . At 6’5”, the little extra reach is desired. Thanks!
