jasontechpro
I sure am glad to be back on a sport bike!
Post by jasontechpro on May 4, 2018 13:23:59 GMT -7
Post by evitzee on May 4, 2018 14:29:14 GMT -7
Looks good, but it appears there is no license plate light(?). Will it pass the annual safety inspection in TX since the criteria requires a functioning plate light? Some places may let it slide, most won't, just something to keep in mind. And it is just another item that the popo's can use to write you up if you are pulled over for any reason. I do see that TST sells a plate light as a stand alone item.
Post by clayton on May 4, 2018 20:19:47 GMT -7
I have the tst installed on my mt10 with there license plate light and love the looks of it. I also installed moto dynamic integrated tail/signal/brake light. I live in Texas so it’s all legal. Best looking kit and only $39 for the fender eliminator kit and light
jasontechpro
Post by jasontechpro on May 5, 2018 5:58:43 GMT -7
I have been looking at integrated lights, I will be sure to check out motodynamic. Did you pick up any frame sliders yet?
Post by clayton on May 5, 2018 8:12:59 GMT -7
I have been looking at integrated lights, I will be sure to check out motodynamic. Did you pick up any frame sliders yet? Yes I got the womet frame sliders from tst at the same time I ordered the license plate bracket
jasontechpro
Post by jasontechpro on May 15, 2018 17:28:59 GMT -7
Looks good, but it appears there is no license plate light(?). Will it pass the annual safety inspection in TX since the criteria requires a functioning plate light? Some places may let it slide, most won't, just something to keep in mind. And it is just another item that the popo's can use to write you up if you are pulled over for any reason. I do see that TST sells a plate light as a stand alone item. I did not opt for the license plate lights yet. It takes no bolts and can be added later, so I figured I would see how much the riding lights work for now.
daver
Post by daver on May 23, 2018 12:57:15 GMT -7
Post by evitzee on May 23, 2018 13:56:14 GMT -7
I actually had the Vagabond in hand but I just didn't like the angle that the plate sat at (too flat). It's a small issue but it bothered me. Sent it back and got the Yoshimura which is more money yet. But liked the way it looked along with the very nice LED light they include. It's all personal choice on how you want your rig to look and how much $$$ you want to spend.
