roosterxp
Post by roosterxp on Apr 24, 2018 15:10:31 GMT -7
Getting my ECU reflashed as we speak. I'm putting the cat back on. Nels told me I don't have to worry about putting the servo and cables back on. How can I make the butterfly valve on the exhaust stay open? Right now it swings both ways..
guywithfz10
Post by guywithfz10 on Apr 24, 2018 18:00:33 GMT -7
I did the same thing. What i did was pull the spring off then load up with around 3 washers then a spring washer in between and put the nut back on top with loctite to hold everything together. Seems to be working well so far.
latte
Post by latte on Apr 25, 2018 7:04:09 GMT -7
I’ve done this in the past by removing the spring and simply safety wiring the butterfly in the open position. Very easy.
