mrhix
Post by mrhix on Apr 9, 2018 7:23:36 GMT -7
Has anyone added these Denali lights to their FZ/MT-10? I am specifically looking for info on the fork mounts and if the mounted lights fit around the stock rads, rad overflow tank, etc. without hitting anything.
Thanks,
MrHix
Post by Deleted on Apr 9, 2018 9:51:52 GMT -7
I have the older version of the D2 on fender mount brackets. The supplied wiring kit works fine with the 10. I didn't check to see if fork mounting was an option but you should be able to see if its possible by looking at the available space on each side with the bars at full lock.
Post by clayton on Apr 9, 2018 9:52:24 GMT -7
A link or pic would help
