jlking1989
Post by jlking1989 on Jan 26, 2018 10:14:10 GMT -7
Can anyone provide any information on TST Industries Flushmount Turn Signals? Snapped one of my front ones today leaving my garage and always thought they stuck out a bit much, anyway. This option is significantly cheaper than most from a brand name I see every now and then. Thanks
Post by heathhudnall on Jan 26, 2018 10:24:28 GMT -7
dewaynehasty
Post by dewaynehasty on Jan 26, 2018 11:42:58 GMT -7
TST unit looks pretty good to me! I wonder if you need the relay.
Post by Deleted on Jan 26, 2018 12:53:25 GMT -7
I had these on my FZ-07.
They work well. I got the relay with mine also, but te FZ-10 has built in resistors for it's led turn signals. So either leave those in, or get the relay. (then you would have to remove the resistors on all turn signals)
Post by Cruizin on Jan 26, 2018 13:16:52 GMT -7
dewaynehasty
Post by dewaynehasty on Jan 26, 2018 14:38:49 GMT -7
OMG so many choices! What to do???
Post by Cruizin on Jan 26, 2018 14:55:29 GMT -7
OMG so many choices! What to do??? Buy em all and light up the night sky!
jlking1989
Post by jlking1989 on Jan 28, 2018 12:25:48 GMT -7
True, but I was looking for a flush mounted signal. The options on revzilla for them seemed few and far between when I was going through them.
dewaynehasty
Post by dewaynehasty on Jan 28, 2018 13:31:44 GMT -7
I just ordered the TST flush mount with the wiring kit but not with the relay. $26 total out the door. I'll let post back after I install them.
dewaynehasty
Post by dewaynehasty on Jan 28, 2018 18:08:40 GMT -7
I just ordered the TST flush mount with the wiring kit but not with the relay. $26 total out the door. I'll let post back after I install them. And I just canceled the order! After looking at a video on replacing the front turn signals it became apparent that the connector is completely different then the wiring harness adapter TST sells for Yamaha. This doesn't look like it is going to work.
jlking1989
Post by jlking1989 on Jan 29, 2018 12:18:21 GMT -7
I just ordered the TST flush mount with the wiring kit but not with the relay. $26 total out the door. I'll let post back after I install them. And I just canceled the order! After looking at a video on replacing the front turn signals it became apparent that the connector is completely different then the wiring harness adapter TST sells for Yamaha. This doesn't look like it is going to work. Well, damn. I just placed an order, yesterday. They're already on the way. I guess I will wait and see when they get here to be sure.
dewaynehasty
Post by dewaynehasty on Jan 29, 2018 13:56:28 GMT -7
And I just canceled the order! After looking at a video on replacing the front turn signals it became apparent that the connector is completely different then the wiring harness adapter TST sells for Yamaha. This doesn't look like it is going to work. Well, damn. I just placed an order, yesterday. They're already on the way. I guess I will wait and see when they get here to be sure. This is from TST support:
DeWayne Hasty Subject: Re: TST Industries, LLC.: Your order #76794 has been processed
JAN 29, 2018 | 10:42AM EST Nate Moye replied:
Hello there,
As per your request I have cancelled and refunded your order. We do not currently offer signals for this bike due to its integrated relay system and plug configuration.
Regards!
Nate Moye TST Industries 386-868-2011
Post by mrcdharwood on Jan 29, 2018 22:59:46 GMT -7
They might not plug straight in but if the lamps are 12v led you can cut the original plug off and join these in directly. That's is if you want them so bad.
dewaynehasty
Post by dewaynehasty on Jan 30, 2018 13:53:36 GMT -7
They might not plug straight in but if the lamps are 12v led you can cut the original plug off and join these in directly. That's is if you want them so bad. I would do that but it would suck if it didn't work. Then you'd have to splice your old signals back on. I think I will wait to see what develops / what others do. I really hate how the stock signals stick out so far.
Post by mrcdharwood on Jan 30, 2018 18:30:28 GMT -7
They might not plug straight in but if the lamps are 12v led you can cut the original plug off and join these in directly. That's is if you want them so bad. I would do that but it would suck if it didn't work. Then you'd have to splice your old signals back on. I think I will wait to see what develops / what others do. I really hate how the stock signals stick out so far. You can always use these... www.carpimoto.it/en-GB/Electrical-Components/Indicator-Wires-Adaptors/47566_EE116H-Indicators-Cable-Kit-plugs-for-Yamaha-MT-10-.htmYamaha indicator plugs with bullets for your new ones. Designed specifically so you don't need to cut original cables. And they're less the €20.
ghostrider1127
Post by ghostrider1127 on Jan 31, 2018 0:55:31 GMT -7
Rizoma adapters
jlking1989
Post by jlking1989 on Jan 31, 2018 8:07:08 GMT -7
Hello there,
Regards!
Good info, thanks so much! Ready to shoot my package back as soon as I get it. Luckily they weren't too expensive
jlking1989
Post by jlking1989 on Jan 31, 2018 8:08:23 GMT -7
Rizoma adapters More info? Does rizoma have a flush mount blinker for the fz-10?
sam07
Post by sam07 on Jan 31, 2018 9:18:28 GMT -7
I thought the front signals are 3 wire. Signal, running, ground. Keep us posted on what you get. Tst’s website has a pick of 2 wire signals. ?
dewaynehasty
Post by dewaynehasty on Jan 31, 2018 14:44:05 GMT -7
I thought the front signals are 3 wire. Signal, running, ground. Keep us posted on what you get. Tst’s website has a pick of 2 wire signals. ? You are correct. TST's websites states that their signals are only signals, no running lights, which is probably what the third wire is for.
