jerryls
Post by jerryls on Jan 22, 2018 22:20:21 GMT -7
Just picked up a leftover 2017 FZ-10, and thought I’d share my initial suspension setup process. None of the following is original, just what I was able to find on the ‘net, along with my experience with previous bikes. The settings I chose below are for a 185 lb rider doing spirited street riding.
A couple things to know going into this:
I find that the fork and shock on a street bike take around 500 miles to “break in”. Before they hit this point, they can be a little stiff and cranky, which can lead you in circles when trying to a good setting. Find an initial setting you can live with, and get the suspension broken in. Then go searching for that elusive perfect setting.
Sag: There are a plethora of videos on Youtube on measuring the sag. Make sure you understand the difference between rider sag and static sag. You set the rider sag, which results in the static sag. The static sag simply tells you if the stock springs are the correct rate, or too hard, or too soft. Don’t waste your time playing with clicker settings until AFTER you set the sag.
1) Setting the shock rider sag. I went with a target of 35mm. After you get the target value, measure your static sag. My static sag was 13mm.
2) Moving on to the fork. My target was 35mm. Static ended up at 26mm. Hint: put a zip-tie on one of your forks.
3) Remeasure your shock sag. When you change the fork sag, it can affect the rear sag. Correct if necessary.
4) Now you can play with the clickers. I found the owner’s manual settings way too soft and bouncy. Knowing that I still had to break in the suspension, I didn’t waste too much time on testing. Here’s where I ended up. Shock: HS = 2 ½, LS = 7 clicks out, Rebound = 4 clicks out. Fork: Preload = 13 turns in, Compression = 7 clicks out, Rebound = 4 clicks out.
I’ll post an update after I get it broken in and have a chance to do some testing.
Jerry
av8er
Post by av8er on Jan 23, 2018 5:36:35 GMT -7
Welcome Jerry! Sounds like this is not your first rodeo. There's a fair amount of info on this forum about suspension settings and you provided some helpful tips for new guys playing with it for the first time. It will be interesting to hear your follow up after breaking in. Many of us have found the rear shock not to be adequate for "spirited street riding". Enjoy your latest scooter! One of the best, all around, I've ever had.
subjectarc
Post by subjectarc on Mar 28, 2018 18:21:40 GMT -7
Great write up. I did the same deal as you with the ‘17. Could you recommend/ link some tools to make suspension adjustments dead simple? I’m sure I’ll be making multiple tweaks so I’d be happy to purchase purpose specific items for this, rather than fuss around with my existing kit. New England is finally warming up so I’ll finishing break-in very soon!
morbo
Post by morbo on Mar 30, 2018 13:30:59 GMT -7
I'm sure someone will correct me if I'm wrong but I don't think there are any truly special tools. The spare pair of hands is going to be the trickiest part for me.
Post by papawheelie on Mar 30, 2018 15:42:44 GMT -7
The spanner wrench, to adjust the rear shock, is the only "special" tool that is needed. If your dealer did the right thing, you should have received one inside one of two tool bags. If your dealer is like mine was, they will look you in the eye and promise you that no tools come with the FZ-10, and you just have to buy your own.
sam07
Post by sam07 on Mar 31, 2018 4:05:10 GMT -7
Nice write up.
