corrado9a
Post by corrado9a on Jan 2, 2018 7:58:26 GMT -7
Hello Guys I have an MT10 SP very recently and i realized something idiotic that i dont understand or maybe i am missing something that i still did not see.
on this bike i cant change the mode on the fly, regardless of having the throttle closed. OK i get it, but the mode is made of PWR level, TCS level, and suspension setting, all of which can be changed on the fly by them selves on the move, but not the mode where all the settings are changed at once.
Is this normal? and can this be tweaked by SW at an aftermarket sw update?
Thamks
superspirit
Post by superspirit on Jan 2, 2018 10:18:58 GMT -7
The mode switch can only be changed while the vehicle is stopped. It states this in the owners manual, performance does not change. Only the throttle map for the grip changes. Performance is actually the same in all 3 modes. The best advice I can give you is to tell you to READ the manual!
corrado9a
Post by corrado9a on Jan 2, 2018 11:45:27 GMT -7
thanks for the advice. If i may respond, i have read the Manual, and i understand that the mode can not be changed on the move. This is what i have stated in my question preface. If could give you an advice my self is to READ my question more carefully, or maybe it is because English is not my first language and maybe not yours as well. Or manybe is becausze on your model you dont have the same options as i do on the SP.
Anyway,The question is why all the settings (PWR, TCS and Susp, setting) that mode change in one "Click" can be changed while in movement and MODE cannot be changed, and if someone knows if it is possible to change that with a Diagnostic Tool entering into a specific menu.
Again thanks
superspirit
Post by superspirit on Jan 2, 2018 13:07:40 GMT -7
Ok,I'll apologize evidently the SP has options the US model doesn't have.
