latte
Post by latte on Jan 2, 2018 12:40:22 GMT -7
This is an awesome deal. You'll need stainless lines to make it all work but the oem FZ10 brake switch will fit and cruise control will function as normal. Add some nice sintered pads and you'll have great stopping power.
ghostrider1127
Post by ghostrider1127 on Jan 4, 2018 17:03:48 GMT -7
Braided lines are not in need , oem will work without problems
latte
Post by latte on Jan 5, 2018 13:21:27 GMT -7
I eyeballed the rubber line to the Nissin fitting, looks like the banjo would twist the hose a bit. Did you have that issue?
jonnyrotton
Post by jonnyrotton on Jan 6, 2018 1:02:44 GMT -7
Stoltec says that it will work plus Richie does an install video with the stock lines. So I guess it will work alright with the stock lines. But for the way I ride (like a grandma) just replacing the pads was all I needed. The radial Master cylinder is supposed to give the best feel, but I realized I wouldn't even use it the way it's intended. So thought I give someone deserving the opportunity to do so and for a good deal.
Post by RedAndBlack on Jan 6, 2018 1:12:45 GMT -7
Jr. I know you already said you're trying to sell the whole thing but let me know if you change your mind, I'd be interested in the mirror mount.
Otherwise this is a great deal for anybody looking to do this mod!!!
mkfess
Post by mkfess on Jan 21, 2018 13:22:25 GMT -7
Will the stock mirror work with the setup? If so, will it be in the same location?
jonnyrotton
Post by jonnyrotton on Jan 21, 2018 18:35:23 GMT -7
Yep, that's what the Brembo mirror mount is for, the stock reverse thread mirror. It is basically the same location, I would say slightly more rearward but not noticably so.
ghostrider1127
Post by ghostrider1127 on Jan 22, 2018 0:04:18 GMT -7
Mirror mount? Just buy the oem from Mt10SP and you are ok
jonnyrotton
Post by jonnyrotton on Jan 22, 2018 0:21:27 GMT -7
Mirror mount? Just buy the oem from Mt10SP and you are ok I'm confused, the sp has the same brake master cylinder as the regular mt/fz which has the mirror mount as part of the master cylinder. So, what do you mean?
ghostrider1127
Post by ghostrider1127 on Jan 22, 2018 4:39:05 GMT -7
Not really as SP got the same master cylinder WITHOUT the mirror mount . yamaha spare parts num. is :34B258671000 for 25 $ Braided lines are not in need for this conversion ,even on SP , MT/FZ 09 or TRACER/FJ 09 (own this bikes and did the swap too ) Also just to be clear , i was the one in april 2016 found out the R1 radial master swap ,headers , wheels and so on (bought the mastercylinder in march even before get my bike) Good Price for the item . Did not understand why no one gonna grab this bargain ...
jonnyrotton
Post by jonnyrotton on Jan 22, 2018 17:57:49 GMT -7
I wish I would have realized that when I was going to do the Master cylinder swap. That part alone cost $40 and the reservoir was $70. So that alone shows the hit I'm taking and the deal on the parts I'm selling truly is. Someone will take advantage.
