yellorice4chu
Post by yellorice4chu on Oct 27, 2017 12:06:20 GMT -7
Is anyone else having cruise control issues? It has been working for me just fine no problem at all... i understand 4th 5th and 6th gear only and its been working just fine until today... Ive checked to make sure there are 2 clicks in the brake lever and there are 2 very positive clicks. To also make sure while riding i pushed the brake lever forward so there was no pressure on it at all and yet it still doesnt turn on. Anyone have any suggestions to what it is i should do?
Post by RedAndBlack on Oct 27, 2017 12:12:47 GMT -7
Are you showing a Check Engine Light? Cruise Control will not run with a CEL present.
And no mean to insult but I think there's a minimum speed requirement on top of the gear requirement. Not sure what it is but make sure you're above that speed which is probably over 40 MPH.
yellorice4chu
Post by yellorice4chu on Oct 27, 2017 12:17:11 GMT -7
yeah i understand no offense taken but ive tried every various speeds with 4th 5th and 6th gear everything ranging from 30-100mph... i went higher out of frustration trying to figure it out but no check engine lights are one they are aftermarket levers BUT they have worked with the levers for 900+miles so i dont think thats the problem
Post by RedAndBlack on Oct 27, 2017 12:27:46 GMT -7
Check the clutch lever, maybe adjust it a little looser and see if that fixes it. Remember the clutch can disengage cruise control as well. And probably the rear brake as well???
I think besides that, I'm out of recommendations. Good luck!
Post by evitzee on Oct 27, 2017 15:10:18 GMT -7
Some aftermarket clutch levers can sometimes be a bit quirky in their fit. Look underneath the lever and make sure the tab is cleanly engaging the switch. Also check the front and rear brake switches, perhaps the adjustment is not quite right. The cruise control can be disengaged in various ways.....pulling the clutch, deploying either brake, rolling the throttle forward or turning it off via the button. I suspect you have an adjustment issue with one of the switch interlocks and not an electronic issue.
yellorice4chu
Post by yellorice4chu on Oct 29, 2017 8:29:50 GMT -7
checked both levers still nothing today im going to try the rear break and adjusting it but if that doesnt do it then im just going to suck it up and take it to a dealer thanks for the help!!!
yellorice4chu
Post by yellorice4chu on Oct 29, 2017 17:18:52 GMT -7
yeah ive also checked both levers the only thing i havent done just yet is readjust the rear brakes which ill have to do probably on tuesday or so. Hopefully thatll work
