latte
Post by latte on Oct 26, 2017 4:24:22 GMT -7
Price dropped to $200. Note- I will be selling these with a new woodcraft shifter. Hey guys, I'm selling my set of Driven Rearsets for $270 shipped USPS Priority. They've been mounted for 200 miles, have not seen the track yet, and are very clean I.e. No scrapes, damage, etc. All hardware included, will also send brand new rear brake pressure switch as I just didn't run the rear switch when these were mounted. The neutral peg position is same as stock, and then you can adjust from there for more aggressive stances to stop your peg or boot from scraping. Things to note: These were designed to work with stock exhaust *orientations*, so if your Akra mid pipe uses its own exhaust bracket, you'll have to fab something up. If your exhaust mounts either with the stock exhaust bracket or in the same position as the stock exhaust, you will be fine. Decat and stock slip on or any slip on using stock bracket will work. Feel free to ask me any questions.
Located in Orlando, FL.
jay9553
Post by jay9553 on Oct 26, 2017 10:53:37 GMT -7
pm sent
wonger
Post by wonger on Oct 26, 2017 11:51:42 GMT -7
Hey guys, I'm selling my set of Driven Rearsets for $270 shipped USPS Priority. They've been mounted for 200 miles, have not seen the track yet, and are very clean I.e. No scrapes, damage, etc. All hardware included, will also send brand new rear brake pressure switch as I just didn't run the rear switch when these were mounted. The neutral peg position is same as stock, and then you can adjust from there for more aggressive stances to stop your peg or boot from scraping. These also allow GP shift with the GYTR quickshifter. One of the main reasons I bought these. Things to note: These were designed to work with stock exhaust *orientations*, so if your Akra mid pipe uses its own exhaust bracket, you'll have to fab something up. If your exhaust mounts either with the stock exhaust bracket or in the same position as the stock exhaust, you will be fine. Decat and stock slip on or any slip on using stock bracket will work. Feel free to ask me any questions. Located in Orlando, FL. I call 2nd dibbs
Post by Deleted on Oct 26, 2017 12:01:47 GMT -7
I have these rearsets on mine and like them a lot. No problems with them. As latte said, if you have an exhaust mount different than OEM you'll have to make it work. I used two pieces of flat aluminum stock as a muffler hanger and attached them to the passenger peg mounts on the subframe.
latte
Post by latte on Jan 7, 2018 1:29:23 GMT -7
Bump these are still for sale
$200 shipped
latte
Post by latte on Jan 7, 2018 1:35:06 GMT -7
Post by deftone on Jan 21, 2018 7:03:46 GMT -7
PM sent
