miglo
Post by miglo on Sept 3, 2017 12:09:38 GMT -7
Two different types available, bar end type and bolt type. I chose the bolt type and decided to mount it at the rear of the bike.  Website: lidlox.comLink to Specific Product Used: lidlox.com/products/8031-b- You can also just email Matt [email protected] and let him know you want the 8mm x 1 3/8" bolt if you go this same route or a different size bolt for another location of your choice... -Tools: 6mm Allen Wrench Small Allen Wrench (comes with kit) Blue Loctite 3/8" drill bit Simple Install Video: Location I choose -Remove 8mm bolt with 6mm Allen.  The Kit with parts:
 Picked up some rubber washers from the plumbing isle at Home Depot to avoid rubbing on the frame. Use a 3/8" drill bit to open up the center hole to fit better.    Apply some blue loctite and tighten with the slot facing the 10-11 o'clock position. This avoids any interference with the rear turn signal when the helmet hangs.   Helmet without T-Bar:  Helmet with T-Bar:  Review: Very happy with it so far. Not an eye sore on the bike and seems very sturdy as far as protection. It's definitely easier to hang with the T-Bar, but I don't really like carrying it in my pocket, so I just hang my helmet directly off the D-rings...
stealthunion
Post by stealthunion on Sept 3, 2017 20:20:21 GMT -7
Miglo - I was looking for something like this. The pics and notes are very helpful. Thanks for sharing. Ride safe, brother!
osiris10012
Post by osiris10012 on Sept 3, 2017 20:28:40 GMT -7
Great info. Thanks for sharing. Wish our bikes came from the factory with this feature.
landmark518
Post by landmark518 on Sept 5, 2017 9:57:12 GMT -7
Nice detailed guide. Thanks!
coyote
Post by coyote on Sept 5, 2017 11:50:52 GMT -7
...it's definitely easier to hang with the T-Bar, but I don't really like carrying it in my pocket, so I just hang my helmet directly off the D-rings... Could you just leave the T-bar attached to the lock all the time instead of putting it in your pocket? Any how,cool lock and thanks for sharing it!
miglo
Post by miglo on Sept 5, 2017 13:33:13 GMT -7
coyote, yes you could, but I would be afraid of it getting snagged on something and wouldn't want it flapping around while riding...I think I have found a spot to store it through, between the frame and seat. Just have to find away to secure it...
cerndo
Post by cerndo on Sept 16, 2017 8:30:12 GMT -7
so, you don't really need the T bar? Just the helmet's D-ring will fit in the lock's slot?
miglo
Post by miglo on Sept 17, 2017 10:41:31 GMT -7
so, you don't really need the T bar? Just the helmet's D-ring will fit in the lock's slot? Yes...It's not easy without the T-bar but that's how I attach mine. There's a gap between the seat and the frame that the T-bar could be slid into and secured, just takes a little ingenuity...
poolfool814
Post by poolfool814 on Apr 10, 2018 10:17:09 GMT -7
Righteous man, ordered mine today. Really appreciate the post!!
