Post by lolibater on Jul 28, 2017 19:55:34 GMT -7
Does anyone else have these? With all the spacers installed it seems to be the exact height as OEM. Not sure if I'm missing a piece or not.
Post by Deleted on Jul 29, 2017 4:06:49 GMT -7
Pics?
Post by lolibater on Jul 31, 2017 8:19:29 GMT -7
It's all good. I talked to another owner and they only come with 2 per side. Since this other guy isn't using any on his, I'll take his 4, for an additional 10mm rise.
duffdad
Still riding the FZ and still loving it.
Post by duffdad on Jan 26, 2018 12:48:30 GMT -7
I used Rox Risers. Only issue was having to have custom made cables. The risers themself raise the bars about 2-3” and allow you to tilt ‘em back to find a nice reaching/arm height position. Highly recommended.
h19hsp33d
Post by h19hsp33d on Aug 2, 2018 21:07:27 GMT -7
I used Rox Risers. Only issue was having to have custom made cables. The risers themself raise the bars about 2-3” and allow you to tilt ‘em back to find a nice reaching/arm height position. Highly recommended. Bought some ROX... Was really hoping for any easy install. What cables did you need to rebuild\customise? Any tips, tricks, photos from your install?
northsouth
Post by northsouth on Aug 12, 2018 8:16:03 GMT -7
You don't need custom cables. You can re- route the stock cables to work. Flip the throttle housing to the underside of the handlebar. You will need to drill a hole in the handlebar to accept the anti rotation stop to the other side. All done.
chuckthebarber
Post by chuckthebarber on Aug 12, 2018 11:36:12 GMT -7
We run Rox risers with stock cables. No drilling. Now, for the position that I prefer the throttle cable housing just had to be twisted just a smidgen to make sure the throttle snaps back while the handle bar was locked to the left.
glock
Post by glock on Aug 13, 2018 12:13:03 GMT -7
We run Rox risers with stock cables. No drilling. Now, for the position that I prefer the throttle cable housing just had to be twisted just a smidgen to make sure the throttle snaps back while the handle bar was locked to the left. Hey chuckthebarber, can i get you to snap a few pics of your setup. The ROX risers say a 2" rise, i dont see my bike having that much play in the cables. Mike
chuckthebarber
Post by chuckthebarber on Aug 13, 2018 18:02:43 GMT -7
Hey Mike. I'll try and get some up tomorrow after work. Now I'm quite sure some positions will have the cables too tight but like I stated the position that I prefer it works just fine. Rox risers rotate and the bar does as well so we have tons of combinations to play with.
A one inch riser usually does me fine btw, so my setup may not be utilizing the full 2 inches.
chuckthebarber
Post by chuckthebarber on Aug 14, 2018 16:38:41 GMT -7
glock
Post by glock on Aug 17, 2018 20:05:06 GMT -7
that's great, thanks for the pictures
wyand69
Post by wyand69 on May 20, 2019 15:26:20 GMT -7
Do you have the bar trun way up? An do you have any problems locking?
techsniffer
Post by techsniffer on May 22, 2019 10:28:43 GMT -7
I considered these to give me more height on my bars, but to be honest, I think it looks janky and stopped considering it immediately. I think I'm going to have a machinist mill up some aluminum risers about 1in tall to go under the stock risers and buy some longer bolts, I wont need to do any cable work and I'm pretty sure it'll give me exactly what I'm looking for.
wyand69
Post by wyand69 on May 23, 2019 4:19:14 GMT -7
Thanks thinking about the same thing. But for me it's because I'm only five foot seven. A little rise will put me all the way back in the saddle. Scared about having cable issues
kratosfz10
Post by kratosfz10 on May 24, 2019 12:20:00 GMT -7
I have these, and with the bars as far back toward the rear as they will go and the bars rotated back as far as they will go without hitting the tank, I have no cable length issues. I did only use the stock spacers, so the bars are only moved back, not up.
