landmark518
Post by landmark518 on Jul 19, 2017 11:57:01 GMT -7
Can anyone provide the instructions to install the OEM Rear Rack? I assume it's pretty simple but wanted to know if any drilling is required or is it simply bolt on. Thnx for the input.
harry76
Post by harry76 on Jul 20, 2017 18:37:38 GMT -7
Its an easy bolt on.
landmark518
Post by landmark518 on Jul 21, 2017 5:26:01 GMT -7
OK thanks, I seen on one of the forums someone said you had to drill holes for the bolts. Do you have a rack installed? If so, can I get a brief description on installation? I plan on buying one used so no instructions will be provided. I want to be sure I know how to install it first.
harry76
Post by harry76 on Jul 22, 2017 6:51:19 GMT -7
I put it on last year, the only holes you need to drill are through plastic and they are easy and are under thee seat.
