b0ules
Post by b0ules on Jul 14, 2017 19:55:50 GMT -7
I'm fast approaching 10000km, and only found this out a few days ago, so wanted to share just in case.
Are you annoyed that your shift light is almost constantly illuminated? And that it's a bit dim to be effective?
Well do I have news for *you*!
Use your best google-fu to find a copy of the service manual. In this case, I used the MT10 manual, page 28 I believe. It shows how to: 1) adjust brightness of LCD dash display, 2) adjust flash cycle - fast, slow or off, (shift light deactivation at higher RPM), and adjust shift light brightness level.
It's all very easy, you press and hold the clock button while you turn the bike on, then the display will change. You'll then use the Clock and Reset buttons to select different modes and RPM settings.
Have a look at that service manual and give it a shot!
Cheers.
Post by 0002s on Jul 15, 2017 17:41:32 GMT -7
Lolz, I set mine day one.
mother
Post by mother on Jul 17, 2017 4:37:41 GMT -7
It's all in the owner's manual as well. No need to turn to the service manual for this one.
Post by evitzee on Jul 17, 2017 12:29:43 GMT -7
I did this pretty quickly as well after I got the old girl home. But I find even with max brightness and having the shift indicator flash instead of just turning on and staying solid it is still too small and too dim to be of real use. I suppose it would work at night but I ride daytime only. I would have liked a bigger, brighter light set at the top of the instrument cluster but we get what we get. It's not a big deal but the light could be better.
audiblepop94
Post by audiblepop94 on Jul 30, 2017 15:14:35 GMT -7
I hate shift lights.. they are a distraction. Probably going to take the display apart and disconnect the light at some point
stonesie
Post by stonesie on Jul 31, 2017 1:00:56 GMT -7
Or just turn it off in the settings, it can either just come on, flash or not come on at all.
Post by Deleted on Jul 31, 2017 3:37:29 GMT -7
I hate shift lights.. they are a distraction. Probably going to take the display apart and disconnect the light at some point Be a lot easier just to shut it off in the settings. LOL
audiblepop94
Post by audiblepop94 on Jul 31, 2017 5:09:26 GMT -7
I hate shift lights.. they are a distraction. Probably going to take the display apart and disconnect the light at some point Be a lot easier just to shut it off in the settings. LOL Ah yes, I concur. I should really go back to school one of these days and learn how to read
sumgi
Post by sumgi on Oct 19, 2017 17:25:47 GMT -7
Good to know there is a way to do this...I figured there was, but I guess I didn't care that much...or I am just too dog gone lazy...which is probably more likely haha
Post by Deleted on Nov 9, 2017 14:03:42 GMT -7
I did this pretty quickly as well after I got the old girl home. But I find even with max brightness and having the shift indicator flash instead of just turning on and staying solid it is still too small and too dim to be of real use. I suppose it would work at night but I ride daytime only. I would have liked a bigger, brighter light set at the top of the instrument cluster but we get what we get. It's not a big deal but the light could be better. Ever find a larger after market shift light? I was just googeling around the internets and found this post haha, probably should have checked here first but eh. Let me know if you ever came up with anything -Tom
Post by evitzee on Nov 10, 2017 12:07:21 GMT -7
I did this pretty quickly as well after I got the old girl home. But I find even with max brightness and having the shift indicator flash instead of just turning on and staying solid it is still too small and too dim to be of real use. I suppose it would work at night but I ride daytime only. I would have liked a bigger, brighter light set at the top of the instrument cluster but we get what we get. It's not a big deal but the light could be better. Ever find a larger after market shift light? I was just googeling around the internets and found this post haha, probably should have checked here first but eh. Let me know if you ever came up with anything -Tom I never actually looked for a bigger light as I really don't need the function, but many more sport oriented bikes have a much larger light usually mounted above the gauge cluster, often with a faceted lens to make it more visible. Yamaha just stuck the small light into the gauge, nice feature but it isn't really usable. In daylight it just isn't powerful enough to be seen to be effective.
slipwrist
Post by slipwrist on Nov 14, 2022 19:01:17 GMT -7
Don't know about new mt10 but shift light on my '18 is worthless.
Post by willl84 on Nov 15, 2022 5:27:16 GMT -7
Don't know about new mt10 but shift light on my '18 is worthless. You can set it to come on at any RPM you want. I just set mine as high as possible so it never comes on.
