botticelli
Post by botticelli on Jul 11, 2017 14:42:38 GMT -7
If I can source most of the parts second hand I'm going to attempt to swap a FZ10 front end onto my FZ07 It has been done before, and looks pretty straight forward. www.bikeexif.com/yamaha-xsr700-ironwood-tw-steelI want to buy the following PM if your willing to sell Front Rim - Yellow Brake Rotors - Black Brake Calipers Forks Bottom triple clamp Front fender - grey
Post by stoltecmoto on Jul 11, 2017 17:52:24 GMT -7
You can open up your options with an R1 front end. Just need the FZ-10's top triple if you want to keep the handlebars. It's all interchangeable.
Post by Deleted on Jul 11, 2017 18:28:32 GMT -7
You can open up your options with an R1 front end. Just need the FZ-10's top triple if you want to keep the handlebars. It's all interchangeable. Thanks for sharing your knowledge, Nick!!!
botticelli
Post by botticelli on Jul 12, 2017 20:30:27 GMT -7
Hmm yes didnt think of that, probably more of them around second hand too. I need the FZ10 bottom tree, but I think i will need to go custom for the top due to different interfaces for the steering stem nut. I think the FZ10 top tree will sit too low, but that might give me more room to slide the forks around. Time for geometry maths. I want the option to keep the bars, I haven't decided if this is going to become an F707R(clipons) or stay a street bike with an FZ-10 front end. You can open up your options with an R1 front end. Just need the FZ-10's top triple if you want to keep the handlebars. It's all interchangeable.
Post by stoltecmoto on Jul 13, 2017 3:58:04 GMT -7
You could use the triple tree off an R1, as well. The forks and steering stem are identical.
mactay
Post by mactay on Aug 25, 2017 13:34:53 GMT -7
DId you end up swapping the front on your FZ07? I'm in the process of research and hunting down dimensions. Any advice would be greatly appreciated. I'm with you on keeping the riser bars.
botticelli
Post by botticelli on Sept 4, 2017 22:28:37 GMT -7
DId you end up swapping the front on your FZ07? I'm in the process of research and hunting down dimensions. Any advice would be greatly appreciated. I'm with you on keeping the riser bars. I'm still working on it. Im sourcing the parts. You need to keep the risers, as clipons will hit the 07 bodywork. I also want the risers to maintain the steering stabilizer mount from the o7 that i run right now. ~Pete
