Post by Cruizin on May 31, 2017 15:18:54 GMT -7
Post by Cruizin on Jun 1, 2017 9:09:12 GMT -7
More coming very soon
Post by Deleted on Jun 1, 2017 9:34:09 GMT -7
Don't forget to add the Titanium Akrapovic Link Pipe to the list.
mother
Post by mother on Jun 1, 2017 9:54:15 GMT -7
rs
Post by rs on Jun 1, 2017 19:56:44 GMT -7
SP Engineering link pipe and carbon canister motogp2. $640 shipped to the states. Had it in less than a week. link SP Engineering
Post by Cruizin on Jun 8, 2017 10:27:05 GMT -7
*Added the Akrapovic Titanium link pipe for use with the Akra slip on. *Added sound clip links to the Akrapovic Full and slip on's *Added Dyno Chart for the Graves Hexagonal Full Exhaust-(chart shows hp/tq with optional ECU flash) See our vendor 2wdw for their custom graves ECU flash for even better performance numbers More Exhaust updates/links will be added soon! Check back for more!
Post by Cruizin on Jun 8, 2017 10:56:19 GMT -7
*Added Remus Slip on Exhaust *Added Remus Link pipe *Added Remus Dyno chart for link pipe and slip on exhaust. (performance numbers reflect euro MT-10 model-See our vendor 2wheeldynoworks for USA ECU tune for similar or even better performance!
Post by Cruizin on Jun 10, 2017 14:37:44 GMT -7
* Added Leo Vince Factory S Slip on exhaust. (no dyno chart or sound clips available currently)
mother
Post by mother on Jun 10, 2017 15:25:04 GMT -7
Here's a pic of the Akra slip on on Armor Grey. I picked up the same sticker as you, Bogie, thinking I'd hate the red in the logo, but I actually don't mind it at all now that the pipe is on the bike. I ordered mine from Revzilla, who gladly matched the price I posted above from Biohazard.
Post by Deleted on Jun 29, 2017 21:34:52 GMT -7
jagermeister
Post by jagermeister on Jun 30, 2017 7:38:45 GMT -7
I like my Delkevic - it's light weight, and much higher quality than the price would suggest. With the baffle in, it's not much louder than OEM, but with a lower rumble. This is the 14" carbon. My only grumble is the Decel popping...not Delkevic's fault - every Cat-free exhaust probably causes it. Even with the PAIR/AIS blocked, the decel popping is annoying. I know some riders actually like it, but it's not for me.
av8er
Post by av8er on Jun 30, 2017 7:59:50 GMT -7
Did you do the block offs yourself? If so are you certain that they are seated properly? There is a tang that some block offs don't have the predrilled hole to seat flat and will not work. I don' t get any pops with mine since I installed the graves block offs. Just a suggestion.
Post by Cruizin on Jun 30, 2017 10:00:34 GMT -7
Did you do the block offs yourself? If so are you certain that they are seated properly? There is a tang that some block offs don't have the predrilled hole to seat flat and will not work. I don' t get any pops with mine since I installed the graves block offs. Just a suggestion. 2wheeldynoworks also has blockoff plates and they only charge like $30 for forum members.
harry76
Post by harry76 on Jul 2, 2017 19:24:35 GMT -7
<img src="//storage.forums.net/forum/images/bbcode/video-preview.png" video="<iframe width="560" height="315" src=" frameborder="0" allowfullscreen></iframe>" alt="Video Preview">
Graves EVR exhaust and Graves tune.
jagermeister
Post by jagermeister on Jul 7, 2017 13:19:58 GMT -7
Did you do the block offs yourself? If so are you certain that they are seated properly? There is a tang that some block offs don't have the predrilled hole to seat flat and will not work. I don' t get any pops with mine since I installed the graves block offs. Just a suggestion. 2wheeldynoworks also has blockoff plates and they only charge like $30 for forum members. Yes, that's what I installed (Graves). FWIW, I also have the 2WDW ecu flash, so it's likely running a bit richer than stock. That, plus a trimmed airbox snorkel. The decel popping isn't a big deal - some days I like it, other days it's annoying.
landmark518
Post by landmark518 on Jul 27, 2017 13:39:15 GMT -7
Post by RedAndBlack on Jul 27, 2017 22:14:31 GMT -7
I like my Delkevic - it's light weight, and much higher quality than the price would suggest. With the baffle in, it's not much louder than OEM, but with a lower rumble. This is the 14" carbon. My only grumble is the Decel popping...not Delkevic's fault - every Cat-free exhaust probably causes it. Even with the PAIR/AIS blocked, the decel popping is annoying. I know some riders actually like it, but it's not for me. Consider getting your ECU flashed. The popping went away on mine with the Delkevic and I haven't even installed the block off plates yet.
seattlerider
Post by seattlerider on Aug 7, 2017 9:45:14 GMT -7
Just bought and installed the Delkevic 14" also, there is a bit of popping on decel at times but it will be going to see Nel at Twowheel Dyno Works soon. Without the baffle it sounds like a 450 dirtbike. Love the look and price
dambikeracer
Post by dambikeracer on Aug 7, 2017 21:54:07 GMT -7
What about the M4?
gfaegenburg
Post by gfaegenburg on Aug 8, 2017 14:18:32 GMT -7
Hey guys, Can someone please help me solve my decal-popping issue. Got the Akapovic Full racing exhaust system and the Power Commander V. The map they gave does not exactly match the exhaust system. Their instructional tips for decal-popping elimination are not working on my bike. (Tried adding 10 and 20 percent on zero throttle from 2000rpm thru 12500rpm and then -10 percent on the same range. Not helping, but was confused that they have you add fuel initially instead of taking away (since the popping is from unburned fuel in the pipes). So I am back to square one. Anybody got a map they have built from a Dyno-Run that is smooth? Help.....Thanks
