Post by 2wheeldynoworks on Apr 30, 2017 16:58:13 GMT -7
Post by RedAndBlack on Jul 10, 2017 13:22:30 GMT -7
Damn, I guess that makes sense why the exhaust was so much cheaper.
Any personal input as to where the few horsepower is being lost in this system compared to the rest?
grant123
Post by grant123 on Jul 10, 2017 13:37:17 GMT -7
Damn, I guess that makes sense why the exhaust was so much cheaper. Any personal input as to where the few horsepower is being lost in this system compared to the rest? My guess, smaller diameter pipe
rs
Post by rs on Jul 11, 2017 20:10:06 GMT -7
is that bad? Doesn't look like it to me.
Post by 2wheeldynoworks on Jul 12, 2017 14:01:18 GMT -7
Performance is a little less than the others but not everyone can spend $2,400 on a full system!
thomascrown
Post by thomascrown on Jul 19, 2017 15:51:11 GMT -7
Doesn't this make less power than factory downpipe & tune?
jagermeister
Post by jagermeister on Jul 20, 2017 9:29:41 GMT -7
Was this dyno run with the baffle in or out?
Post by RedAndBlack on Jul 20, 2017 14:32:43 GMT -7
Doesn't this make less power than factory downpipe & tune? Stock I thought was 138 so no on that front. But who knows with a Tune. I'm sure a stock exhaust with a tune might put down more power. These bikes are held back so much by their ECUs and emissions requirements.
stonesie
Post by stonesie on Jul 29, 2017 7:59:52 GMT -7
I'm not going to say they're all like this but mine had a step in the Y pipe.
thomascrown
Post by thomascrown on Aug 2, 2017 19:44:24 GMT -7
Wow! That's terrible.
Post by deftone on Jan 29, 2018 6:23:46 GMT -7
Performance is a little less than the others but not everyone can spend $2,400 on a full system! ...or wants to.
Post by Deleted on Jun 13, 2018 18:10:51 GMT -7
I just got the flash and I am using the Delkevic. It is very interesting that the stock flash gets 151hp, which is less than the 3/4 setup here. Crazy! I'd be better off removing the Delkevic and putting the stock pipe and cat back on!
Post by deftone on Nov 15, 2019 4:36:20 GMT -7
I just got the flash and I am using the Delkevic. It is very interesting that the stock flash gets 151hp, which is less than the 3/4 setup here. Crazy! I'd be better off removing the Delkevic and putting the stock pipe and cat back on! Hard to argue with the stock flash at 151hp but don't forget the Delkevic cuts about *12lbs. which also benefits braking and handling. Sounds pretty nasty, too.
