stlr1
Post by stlr1 on Feb 25, 2024 15:58:08 GMT -7
So I'm looking at doing a muffler and y-pipe on my 2023 MT10. I would like to eliminate the O2 sensors, EXUP, and add smog plates but I also don't want to loose cruise control. Has anyone done this and had success with the elimination plugs. I've seen tuners call out the issue with the ECU needing to see the connection but I don't want to have parts on the bike which aren't needed.
Post by willl84 on Feb 26, 2024 4:55:49 GMT -7
From what I've seen you need to have them still plugged in. I've yet to see reports of anyone using bypass plugs and it working.
2WDW would be the ones to email, Nate's great and responds to messages quickly.
nokz
Post by nokz on Mar 6, 2024 12:02:28 GMT -7
I know the O2 errors for bad readings can be disabled, but I believe the newer gen requires a signal regardless. You can remove the EXUP valve and AIS without issues as those error codes can be disabled when tuned.
