Post by bigmeanbluemachine on Feb 9, 2024 7:03:29 GMT -7
Hi everyone,
My steering head bearing is shot and i need to change it. According to the service manual, to undo steering head ring nut i need a couple of special tools, such as steering nut wrench and ring nut wrench.
I wonder if somone can reccomend cheap alternatives because Yamaha original tools are quite expensive, for what a very limited use.
travis
Post by travis on Feb 9, 2024 8:56:14 GMT -7
Get a 1/2 inch drive castle nut tool on eBay. It's worth the expense TRUST ME, you want good tools for this task. www.ebay.com/itm/115950112864 Confirm with the seller that this'll fit the MT10. I ordered from this seller a couple years back and they shipped to Cal, US no issues. Was like 40 bucks total. Easy to work with the torque wrench, the socket stays in place unlike a cat's paw tool that wants to slip, fall off and gouge the nut. As for the bearing driver tools there are some options.
and this motion pro driver
Post by willl84 on Feb 9, 2024 10:27:15 GMT -7
Good thing this popped up here today. Thinking of pulling my triples to get them powder coated. Already found that All Balls makes a tapered roller kit instead of the shitty round rollers that come stock.
Post by bigmeanbluemachine on Feb 10, 2024 6:33:54 GMT -7
Get a 1/2 inch drive castle nut tool on eBay. It's worth the expense TRUST ME, you want good tools for this task. www.ebay.com/itm/115950112864 Confirm with the seller that this'll fit the MT10. I ordered from this seller a couple years back and they shipped to Cal, US no issues. Was like 40 bucks total. Easy to work with the torque wrench, the socket stays in place unlike a cat's paw tool that wants to slip, fall off and gouge the nut. As for the bearing driver tools there are some options. and this motion pro driver
Thank you. Saw this drive castle online and glad to see someone used it successfully. Much better price than an OEM tool. What about Steering nut wrench (assume this is the one you called cats paw)? Do i still need one for the job? I am asking because service Manual states: "Hold the lower ring nut with steering nut wrench, and then remove the upper ring nut with the ring nut wrench".
travis
Post by travis on Feb 10, 2024 17:26:17 GMT -7
I just compared the mt10 manual to my fz09 manual (I did the procedure on my fz09) and the setup looks almost identical. Reassembly torques are the same; 38 ft-lb to initially set the bearings, back it off, set final to 10 ft-lb. Install rubber o ring/washer, then the top lock nut finger tight, aligning the two nuts so that the lock washer can slip down and bridge the two together. Then the rest of the stuff gets installed beyond that. I see the line of text you reference "Hold the lower ring nut..." for disassembly. Now if your steering stem was assembled correctly then the two nuts should not be jammed together, instead the top nut should only be finger tight. I suppose there could be a chance that it is not, and in that case they're advising to hold the lower nut so they can be separated and or don't just spin off together. I didn't need an extra holding tool to get the top nut off. I would have improvised if that were the case. Buying the terribly overpriced yamaha specialty tools not an option. If I may suggest additional tips that will make the job much safer- I had the bike almost fall off the floor jack while raising and lowering it trying to get shit to line up. It was *real* close to becoming a disaster, one kind where someone could get hurt. After that close call I bought a $60 scissor jack from home depot. www.homedepot.com/p/STARK-USA-1100-lbs-W-Deck-Scissor-Lift-Jack-Motorcycle-Center-Hoist-Stand-for-Bike-ATV-in-Blue-65127/320573518?source=shoppingads&locale=en-USI guess if I'd taken the forks completely off (I was just greasing the bearings at the time) then it would have been better but still, this little jack is 1000 times more stable than a floor jack or suspending the whole bike from the rafters. That shit is sketchy. The little scissor jack works perfect just under the headers, they supported just fine no dents nothing. Might be a good idea to safety tether the bike to a rafter or something too. You know how it goes when we start wrastling around on stuff.
Post by bigmeanbluemachine on Feb 11, 2024 13:46:45 GMT -7
Thanks for some great tips Travis! Will definately apply them on this job. And yes, i was about to suspend the bike with some heavy duty straps. I like your idea to use a scissor jack way better Did you remove downpipes to lift the bike with a scissor jack?
travis
Post by travis on Feb 12, 2024 9:49:16 GMT -7
Post by hooli on Feb 13, 2024 11:57:00 GMT -7
How did you remove the lower bearing from the steering stem?
travis
Post by travis on Feb 14, 2024 10:51:55 GMT -7
I only did a re-greasing of the bearings, didn't replace the bearings & races.
Post by willl84 on Feb 15, 2024 6:30:22 GMT -7
How did you remove the lower bearing from the steering stem? I've always used a die grinder with a cutoff wheel.
Post by bigmeanbluemachine on Feb 27, 2024 15:45:42 GMT -7
At the moment, I am completely stuck trying to remove the lower steering head race from the frame. As per the service manual, you should be able to remove with a long rod and a hammer, by banging on the lip of the race. Unfortunately, the lower race doesn't have any lip that I could hit with a rod to remove the race from the backet. It is so much in line with the bracket, that I barely can feel the end of the race with my finger. Would be happy to hear any wild ideas how to remove it. P.S. I got myself Motion Pro Steering Head Race Puller, which unfortunately was just a bit too small to do the job by a few mm.
Post by willl84 on Feb 27, 2024 16:17:47 GMT -7
At the moment, I am completely stuck trying to remove the lower steering head race from the frame. As per the service manual, you should be able to remove with a long rod and a hammer, by banging on the lip of the race. Unfortunately, the lower race doesn't have any lip that I could hit with a rod to remove the race from the backet. It is so much in line with the bracket, that I barely can feel the end of the race with my finger. Would be happy to hear any wild ideas how to remove it. P.S. I got myself Motion Pro Steering Head Race Puller, which unfortunately was just a bit too small to do the job by a few mm. P.S.S. I don't understand how to post an image here -> freeimage.host/i/screenshot-2024-02-27-232706.JGb9c2jIt should tap out with a hammer and long punch. I've had some that were tricky and you had to hold the punch just right to get it to catch. Also don't hit it all on one side or you'll never get it. Usually tap in at least two places 180° apart, 3-4 equal distance around works best
Post by bigmeanbluemachine on Feb 28, 2024 3:26:04 GMT -7
Yes, I get how it works in theory. Seen every video on youtube i could find, at this point Problem for me is, that there is no lip on the race that i can tap on. It's like one smooth surface. You can see the gap between the race and the bracket but if i put my finger on it, it is like it's not existing.
Post by willl84 on Feb 28, 2024 6:24:14 GMT -7
Yes, I get how it works in theory. Seen every video on youtube i could find, at this point Problem for me is, that there is no lip on the race that i can tap on. It's like one smooth surface. You can see the gap between the race and the bracket but if i put my finger on it, it is like it's not existing. That's really strange. I haven't done mine yet and won't be until this summer (or maybe next winter) when I powder coat my triples so I can't give any advice unfortunately. Is there any way you could get a puller in from the bottom somehow?
Post by bigmeanbluemachine on Feb 28, 2024 8:05:06 GMT -7
Well that is what that Motion Pro tool was supposed to do for me but unfortunately, their race puller was not big enough. I also tried to use one of those cheap Amazon tools: it helped me to remove the top race, because it could grip on the lip of it. Unfortunately lack of lip on bottom race means, it just falls out after a few bangs.
travis
Post by travis on Feb 28, 2024 16:18:59 GMT -7
It's flush to the tube?!
How about this thing: Pit Posse PPRT2 Motorcycle Headset Cup Remover Tool
Post by bigmeanbluemachine on Feb 29, 2024 2:50:26 GMT -7
Ah yes, I've got a similar tool and tried to use on this job. It's called Park Tool RT-2. Same concept as the one you've suggested. Long story short, this tool does not work on this bike This is because, the race sits at the bottom of the steering shaft. Diameter of the shaft at the very bottom / top, where the race sits, differs from the rest 95% of the steering shaft. Place where the diameter of the shaft changes is quite abrupt creating a small corner, quite close to the race, which gets in the way of the tool you've mentioned. If the shaft diameter was universal this tool would most likely help me. Anyhow, now i have an idea is to use dremel tool, to carefully carve out two ledges on both side of the race. I should be able to then use a classic method of long rod and a hammer, to force the race out of the bracket. Wishe me luck lol!
Post by bigmeanbluemachine on Mar 10, 2024 6:16:40 GMT -7
So it finally budged (hurray!) and i removed the bottom race, by making deep grooves so that my cheap amazon tool could lock into it.
Now here is the interesting thing i discovered, why it was such a hassle for me to remove it. When the steering bearings were replaced last time, the mechanic used an incorrect set. So both the upper and bottom races had a slightly wider diameter on the side that sits against the hub. The bearing set still did it's job and the only problem was the lack of lip on disassembly.
With the new race in place, I can see it has a protruding lip, so next time there will be no trouble removing it as per the manual.
I hope it helps anyone who might find themselves in a similar situation. Thanks everyone for your tips and suggestions.
travis
Post by travis on Mar 10, 2024 9:22:06 GMT -7
Hey thanks for following up! Too many times folks just bail out and leave us hanging. Did you replace with tapered rollers or OEM style round?
