sussybro
Post by sussybro on Nov 22, 2023 17:22:01 GMT -7
So, while swapping sprockets all was going smooth and quick until I finished and noticed the chain changes tension by quite a bit in different spots. Chain js brad new good DID chain too. Here's a video of it. Plus yes I know running in gear on a stand is kinda dumb but I had to for the video. Im also pretty sure bearing and all are fine.
Post by mindcrime79 on Nov 23, 2023 1:09:46 GMT -7
You're describing a worn chain but I see that you've replaced it and it's brand new. Something isn't straight. Did you check if the rear sprocket was seated correctly and/or is the wheel straight at the rear.
Post by willl84 on Nov 23, 2023 3:13:33 GMT -7
Like mindcrime said that's typically a worm chain issue. What rear sprocket is that? I've seen a few that weren't machined properly and weren't concentric and caused the same issue.
terrys
Post by terrys on Nov 23, 2023 12:31:31 GMT -7
Is the chain really loose and tight? I know when you run a bike on the stand like that the apparent tension can vary just due to the ease of the wheel rotating. You might get a better idea if you were to ride the back brake slightly to cause some drag. How does this feel when you are riding?
Post by mindcrime79 on Nov 23, 2023 23:13:13 GMT -7
I think we're talking to ourselves here. I'd be surprised if he comes back. 🤦
kyle
Post by kyle on Nov 24, 2023 8:46:33 GMT -7
Is the chain really loose and tight? I know when you run a bike on the stand like that the apparent tension can vary just due to the ease of the wheel rotating. You might get a better idea if you were to ride the back brake slightly to cause some drag. How does this feel when you are riding? That's one thing that I've noticed as well. Every time I run the bike on the stand (not often) the tension changes and the chain slaps around. I've replaced the chain/sprocket on my FZ8 just to get the same behavior.
