outwithjack
Post by outwithjack on Dec 22, 2022 2:34:15 GMT -7
Barkbusters and swmotech type hand guards ..... I think you can get them with led indicators ! Does the mt10 2019 have an auxiliary plug in anywhere for this use or do you need to brake into the original wires ? Just asking ?
exdomer
Post by exdomer on Jan 27, 2023 10:18:21 GMT -7
They make them for 2022 and up Mt 10 So far only available from Europe I got a set and they look awesome, but I had to pay dearly for them due to exchange and shipping duty etc. Worth it if you want them.
exdomer
Post by exdomer on Jan 27, 2023 10:30:32 GMT -7
Post by Deleted on Jan 27, 2023 10:49:20 GMT -7
Really interested to see these on your bike!
exdomer
Post by exdomer on Jan 27, 2023 14:25:32 GMT -7
This isn’t my bike, but it is what they will look like
Post by Deleted on Jan 27, 2023 14:29:29 GMT -7
Man I like those!
Post by parthz8 on Feb 1, 2023 11:54:53 GMT -7
I bet you have to tap them to one of the ACC wire, may be to DRL always ON/HOT Indicator wire. MTs dont have any spare connections for these accessories. Or you can attach them to AUX DC socket with 12V adaptor.
Post by willl84 on Feb 2, 2023 10:21:39 GMT -7
I bet you have to tap them to one of the ACC wire, may be to DRL always ON/HOT Indicator wire. MTs dont have any spare connections for these accessories. Or you can attach them to AUX DC socket with 12V adaptor. If they're meant to function as signals and not just running lights then you'll have to hook them into the signal wires. If they're just marker lights then any 12V switched supply should do.
exdomer
Post by exdomer on Feb 2, 2023 13:49:29 GMT -7
You wire them directly to the OE turn signals. The OE ones get removed and a rubber blanking plate is used to cover the holes. The hand guards get the wires fished through the handle bars and out an existing hole at the centre of the handlebars on the bottom. They are supplied with bullet connectors that you then connect to the wires that you just fished through. The other wire they supply has one end that is the bullet connector and the other end is the connector that will go to the turn signal pigtail that is part of the wiring harness. All plug and play. Hardest part is fishing the wires through the handlebars.
senseicp3
Post by senseicp3 on Feb 9, 2023 9:46:19 GMT -7
Hey, I was looking all over for this. "" and out an existing hole at the centre of the handlebars on the bottom." I guess there is pre-drilled holes on the handle bars. Are there instruction pictures available? Thank you.
exdomer
Post by exdomer on Feb 13, 2023 12:08:49 GMT -7
exdomer
Post by exdomer on Feb 13, 2023 12:41:20 GMT -7
Messed up sequence Look at the bottom right of each page for number
tacii
Post by tacii on Oct 18, 2023 23:54:57 GMT -7
Are these plug and play?
dougiequick
Post by dougiequick on Dec 9, 2023 18:08:23 GMT -7
I am really interested in handguards as in wind protection (similar to what came standard on my Tracer 9gt) but also with integral turn signals because I hate the OEM MT-10 blinkers which have been knocked loose several times....I would rip them right out if I had em in handguards! IF I could find a nice looking blanking plug to fill the egg shaped hole left behind LOL ...trouble is I dont see em offered for 2022+ which has three wird signals and also the new Brembo brake master....if it were the older gen MT-10? SW Motech "Kobra" very impressive! Just wont work on my 2023 dang it
wintersdark
Post by wintersdark on Dec 11, 2023 10:20:51 GMT -7
I am really interested in handguards as in wind protection (similar to what came standard on my Tracer 9gt) but also with integral turn signals because I hate the OEM MT-10 blinkers which have been knocked loose several times....I would rip them right out if I had em in handguards! IF I could find a nice looking blanking plug to fill the egg shaped hole left behind LOL ...trouble is I dont see em offered for 2022+ which has three wird signals and also the new Brembo brake master....if it were the older gen MT-10? SW Motech "Kobra" very impressive! Just wont work on my 2023 dang it As a middle ground solution, maybe replace the fronts with some TST flush mount indicators and add handguards? You can actually mount the Tracer handguards (2nd gen are the ones I've used) on the MT10 with a little work. They thread directly into the ends of the bars. However, the plate where they attach to the mirror doesn't quite line up, it's about 1/3 of an inch out of position. You can fully remove this plate and only attach the handguards by the bar ends (which works fine, and I've done), move the control clusters and mirrors inboard a little bit (there's enough room on the 2023; I've experimented with this) and connect them "properly", or make a replacement bracket that fits the stock control positions. Mostly because my Tracer was stolen, and I had the hand guards off at the time so I was left with a pair of Tracer handguards and nothing to do with them.
