jregert
Post by jregert on Sept 9, 2022 1:52:54 GMT -7
Anyone done the RCS 19 master cylinder on their bike? How do they like it? I just installed an RCS 19, wave rotors, galfer pads, Moore mafia flash, -1 rear sprocket, and I’m waiting on my core moto brake lines to come in to bypass that abs I’m antsy and can’t wait to see how the brakes perform now, also excited to see if the flash makes a noticeable difference.
Post by willl84 on Sept 9, 2022 3:51:54 GMT -7
I bought the R1 kit from Stoltec Moto with the Spiegler lines. Why get rid of ABS? Mine has already saved me. The flash makes a difference. Can't speak for MM as mine is 2WDW.
jregert
Post by jregert on Sept 9, 2022 6:10:46 GMT -7
I bought the R1 kit from Stoltec Moto with the Spiegler lines. Why get rid of ABS? Mine has already saved me. The flash makes a difference. Can't speak for MM as mine is 2WDW. It has been pretty intrusive at the track, I also go tired off the abs pulsating when you’re grabbing a handful of brake coming into a corner. I would rather regulate the brake pressure my self instead of relying on a computer to correct it. But on the street yes I believe abs is a great thing.
Post by willl84 on Sept 9, 2022 6:21:54 GMT -7
I bought the R1 kit from Stoltec Moto with the Spiegler lines. Why get rid of ABS? Mine has already saved me. The flash makes a difference. Can't speak for MM as mine is 2WDW. It has been pretty intrusive at the track, I also go tired off the abs pulsating when you’re grabbing a handful of brake coming into a corner. I would rather regulate the brake pressure my self instead of relying on a computer to correct it. But on the street yes I believe abs is a great thing. Track makes sense. I do notice my rear pulsing when I get on the brakes hard on the street
jregert
Post by jregert on Sept 9, 2022 6:41:29 GMT -7
It has been pretty intrusive at the track, I also go tired off the abs pulsating when you’re grabbing a handful of brake coming into a corner. I would rather regulate the brake pressure my self instead of relying on a computer to correct it. But on the street yes I believe abs is a great thing. Track makes sense. I do notice my rear pulsing when I get on the brakes hard on the street Yeah the rear isn’t so bad it’s just not a great feeling when it pulses up front haha
r1loon
Post by r1loon on Aug 13, 2023 15:47:19 GMT -7
fztenn
Post by fztenn on Aug 14, 2023 5:42:14 GMT -7
Not to hi-jack the thread here, but interested in that lower fairing...any info for the rest of us? Also...kudos for making that bike "YOURS" by thinking outside the box in regards to styling!
torquecrazy
Post by torquecrazy on Nov 1, 2023 7:03:25 GMT -7
So what's the verdict after all the work has been completed? I did the same stuff except I went with Brembo pads and a tune from Nels@ 2 wheel duno. After his tune I definitely needed to have better stopping power. Did you happen to change the tooth number on the back or front? I've been thinking about it, but unsure if I should change the front or back. First gear is so tall and becomes a pain if u get cought in stop and go traffic. Any suggestions?
kyle
Post by kyle on Nov 1, 2023 13:02:55 GMT -7
So what's the verdict after all the work has been completed? I did the same stuff except I went with Brembo pads and a tune from Nels@ 2 wheel duno. After his tune I definitely needed to have better stopping power. Did you happen to change the tooth number on the back or front? I've been thinking about it, but unsure if I should change the front or back. First gear is so tall and becomes a pain if u get cought in stop and go traffic. Any suggestions? I've also been looking into a brake upgrade... Do you find that just the brake pads are enough to make a considerable difference? (Sorry to partially derail this post)
bmwd40
Post by bmwd40 on Nov 2, 2023 4:37:51 GMT -7
I installed Galfer sintered pads and Galfer Wave rotors on my 2021 MT-10 and it made a big diffrence even with the stock brake lines and master cylinder, however I also have Carrozzeria forged alumninum wheels. I will replace the brake lines when their service life is up. I would say try quality pads before you spend big bucks on lines and master cylinder.
