mesarec
Post by mesarec on Jun 14, 2022 9:37:40 GMT -7
So the female end after removing the O2 sensors...can I ride with those undone and not covered? Or am I better off leaving my O2 sensors all connected with a tune and exhaust and waiting for the covers from beaverpower to come in. Tia
Post by mt10orc on Jun 14, 2022 12:54:39 GMT -7
Post by RedAndBlack on Jun 14, 2022 16:50:04 GMT -7
Mine are open and have been for years. O2 sensors were disabled with my tune. No problems.
mesarec
Post by mesarec on Jun 15, 2022 12:11:13 GMT -7
Thanks guys, when you say open? do you mean you undid the o2 sensors, plugged the link pipe and just left the electrical ports open on each side of the bike for years now?
Post by mt10orc on Jun 15, 2022 13:23:11 GMT -7
That is correct. I plugged mine and RnB didn’t. Looks like u can go wither way. I’m just OCD and wanted to cover ‘em.
Post by willl84 on Jun 15, 2022 18:00:12 GMT -7
I plugged mine as well. 2WDW says you don't need to and they've never seen corrosion issues however here in the Northeast we have road salt and humidity. I'll spend the couple $ to have peace of mind honestly.
998noob
Post by 998noob on Jun 17, 2022 7:41:32 GMT -7
That is correct. I plugged mine and RnB didn’t. Looks like u can go wither way. I’m just OCD and wanted to cover ‘em. So I understand you can leave those hole open? Would that cause an exhaust leak?
Post by willl84 on Jun 17, 2022 9:08:21 GMT -7
That is correct. I plugged mine and RnB didn’t. Looks like u can go wither way. I’m just OCD and wanted to cover ‘em. So I understand you can leave those hole open? Would that cause an exhaust leak? They're talking about the wiring connectors, not the exhaust ports. You definitely want to plug the exhaust ports lol
998noob
Post by 998noob on Jun 17, 2022 11:17:01 GMT -7
So I understand you can leave those hole open? Would that cause an exhaust leak? They're talking about the wiring connectors, not the exhaust ports. You definitely want to plug the exhaust ports lol Gotcha!
Post by RedAndBlack on Jun 17, 2022 12:09:23 GMT -7
I plugged mine as well. 2WDW says you don't need to and they've never seen corrosion issues however here in the Northeast we have road salt and humidity. I'll spend the couple $ to have peace of mind honestly. That's a great point. I live in the dry Southwest and almost never ride in any type of bad weather (I've become a fair weather rider hahahaha).
Post by RedAndBlack on Jun 17, 2022 12:11:55 GMT -7
They're talking about the wiring connectors, not the exhaust ports. You definitely want to plug the exhaust ports lol Gotcha! The threads for the exhaust ports match the oil drain plug for most of the common Nissan car plugs. I saved myself some money by going that route. I drilled the heads of the bolts and safety wired them in case they ever came loose.
gtayl09
Post by gtayl09 on Oct 20, 2023 15:17:04 GMT -7
Old thread with a new question. If the O2 sensors were disabled via the tune (moore mafia)- is it ok to just leave the o2 sensors plugged in? The thought of all the work to get to where they plug in doesnt seem worth it unless you absolutely have to.
fatboytom51880
Post by fatboytom51880 on Apr 25, 2024 5:25:21 GMT -7
I also wanted to know if I have to unplug,but then disables cruise control.
