seancusmc
Post by seancusmc on Mar 20, 2022 16:00:58 GMT -7
So I just installed a new battery incorrectly for about a second. I blew the main fuse. I replace it and when I put the key in, the screen looks normal but it won’t start. The engine tries to turn over, the new battery is strong, but it won’t actually run. It will put once or twice every couple of seconds. But that’s all I get. I connected an engine code reader to it and I get 1 error code. P0638 Throttle Actuator control performance/range Bank 1. Does anyone know hot to fix this. I’m hoping it’s just another fuse I need to replace. I am pretty upset with myself for making such a boneheaded mistake. Was really looking forward to riding today.
Post by RedAndBlack on Mar 20, 2022 16:54:40 GMT -7
Yikes. I would go through all of the fuses and see if any others tripped and replace. Inspect the wiring harness as best as you can to see if anything fried. From there would be checking voltages of the various components, and then seeing if the ECU got fried.
Usually if you're lucky, it only blows the main fuse but since you replaced that, I'm thinking you're not so lucky. Good luck.
Post by willl84 on Mar 20, 2022 16:55:36 GMT -7
Like RedAndBlack said - check all your other fuses as well. If they're all good remove the battery again and let it sit for a good 10 minutes with it disconnected. Reconnect and try again.
Post by RedAndBlack on Mar 20, 2022 16:58:20 GMT -7
Also, sometimes the reverse polarity can damage the battery. Might be a good idea to try a new one. Batteries do weird things when theyre on low charge. I can imagine they do even weirder things when you hook them. Up backwards.
ghostrider
Post by ghostrider on Mar 20, 2022 19:44:29 GMT -7
I agree - battery may have e shorted out internally. You can hook a voltmeter up while you are cranking it and see how far it drops. If the voltage is low you will get all sorts of codes because nothing gets the correct supply voltage. Or just pick up another battery and try it.. or try the old one of it still works. Don't know if you were replacing because of failure or preventative.
seancusmc
Post by seancusmc on Mar 21, 2022 7:01:19 GMT -7
Thanks guys. I’m gonna work on it today. Hopefully it’s just another fuse. I’ll post what I find and hopefully I find the answer and this thread helps someone in the future
seancusmc
Post by seancusmc on Mar 21, 2022 7:48:33 GMT -7
It was a fuse! Looks like a lucked out. Thanks for the help guys. I circled in the picture. Fuse box on the right. Third fuse down. It’s the electronic throttle control, which made sense considering the code I was getting from the odb2. The spare came out of the fuse box on the left. the bike was idling rough, but I cleared the code and it is running normal now. thanks for the help.
Post by willl84 on Mar 21, 2022 8:02:03 GMT -7
Nice! Glad it was just a simple fuse!
Post by RedAndBlack on Mar 21, 2022 9:43:21 GMT -7
Whewwww!!! Glad it was a simple fix!
kyle
Post by kyle on Mar 21, 2022 10:34:45 GMT -7
Glad to hear that it was just a simple fuse Funny story - one time I was outside a Cycle Gear and someone installed their battery backwards. We started trying to get to the fuse box with limited tools (PITA). The exact same fuses blew on his too.
Post by RedAndBlack on Jun 15, 2022 11:40:20 GMT -7
jwhite17fz10
Post by jwhite17fz10 on Mar 23, 2023 12:13:08 GMT -7
For what it worth..I just repeated your error.feel just as stupid..im 48 years old and this is easily like my 15th street bike..never have I been so dumbfounded. Your picture and write up of the 2nd 7.5amp fuse saved me. Bikes running. Thanks to you all
maciasan
Post by maciasan on Oct 18, 2023 15:25:42 GMT -7
You guys just saved my Yamaha mt 07 😆 The same problem with opposit battery connection. Just changed main fuse and everything AGAIN works perfect! THANK YOU!
goodman4
Post by goodman4 on Apr 20, 2024 21:44:36 GMT -7
So glad to have found this thread. I did exactly the same stupid thing yesterday. After blowing the 50 amp fuse and noticing I was putting red on “-“ I was so mad Yuasa switched terminal orientation. If I’d got a different battery I would’ve probably checked more. It’s common to add stubborn to stupid so I was experimenting with whether to turn the battery around (cables won’t reach), rewire positive and negative cables (very difficult) or send back the battery to Yuasa. I got on the forums to see how other people dealt with it and what do you know, they fix it by putting the battery in the right way - on its side. Duh! Now it looks like the original.
Also I blew a different 7.5 amp fuse from most other people. Mine was the ABS. All is good today. Thanks for the help.
travis
Post by travis on Apr 21, 2024 13:01:48 GMT -7
FYI reverse terminal batteries are a thing. Sometimes there is a "-R" part number designation.
