Post by 0002s on Nov 29, 2016 18:35:50 GMT -7
This one is real simple. You'll need the following: 4mm allen head 6mm allen head 8mm allen head 1. Remove black exhaust cover plate using 4mm allen head 2. Slide cover towards front of bike to remove 3. Loosen exhaust top mount bolt with 8mm allen head but do not remove 4. Remove bracket that tightens exhaust to pipe using 6mm allen head. This mount is hinged and there is an hinged bracket, collar and greased ring. 5. Once pipe bracket is removed, continue to remove the exhaust mounting bolt using 8mm allen head and slide the exhaust off. 6. Below are all 5 pieces you should have removed. You are done. This should take no more than 15 minuets to complete.
Post by Cruizin on Nov 29, 2016 21:15:07 GMT -7
Wow, that was so thorough anyone can swap in a new exhaust now. Thanks man!
What did ya put on?
Post by 0002s on Nov 29, 2016 21:25:44 GMT -7
Post by Cruizin on Nov 29, 2016 21:41:59 GMT -7
Saw that right after I asked, lol
Post by Deleted on Nov 30, 2016 4:30:42 GMT -7
Nice write up!!!
audiblepop94
Post by audiblepop94 on Apr 22, 2017 20:22:41 GMT -7
I just took the stock can off and left the big ugly box for now while I wait on the Hindle cat-delete can, honestly it sounds great for a stock cat box, and it is a very tolerable noise level.
A tip for the budget riders...
