nikond5
Post by nikond5 on Nov 6, 2020 5:22:47 GMT -7
Just purchase an MT-1010 2020 they have Bridgestone BATLAX HYPERSORT S20F Front 36 PSI S20R Rear 42 PSI Going to my first track day and would like to know if PSI needs to be different or do I just leave as recommended by manufacturer for normal riding. I appreciate the help or guidance
Post by Deleted on Nov 6, 2020 7:26:43 GMT -7
Personally I'd start the day off around 28 front and 35 back. Check pressure each session and let air out as the tires heat up and air expands.
Post by dkim213 on Nov 7, 2020 1:24:59 GMT -7
Good starting point would be around 32/30 front/rear cold.
Post by RedAndBlack on Nov 8, 2020 17:15:59 GMT -7
That's a good starting point.
I do run the stock tires at 31/30 WARM. But it's all relative to track conditions. I'm mostly riding in the desert, hot ambient and track temps.
It's really something you have to play with during the day. I usually have to adjust my tire pressure until halfway through the day.
