weirdo
Post by weirdo on Feb 24, 2020 2:48:43 GMT -7
Just done valve clearance inspection at 33000 km, on exhaust side was 0,13. 0,18. 0,10. 0,10. 0,09. 0,13. 0,12. 0,08mm it lower than I expected, on intake all valves was 0,12-0,13 which is realy good. Service manual says Ex. 0,20-0,26mm and
In. 0,09-0,17mm. I would recommend to do valve clearance check at least around 20000 km and not wait specified service at 40000 km.
Post by RedAndBlack on Feb 24, 2020 14:45:52 GMT -7
Any tips or tricks regarding getting to the valves? I've stripped the bike down to do spark plugs but haven't gone further than that. There's always these little tips and tricks you find out later that you wish you knew at the time.
b0ules
Post by b0ules on May 2, 2020 21:14:16 GMT -7
+1
Post by rracerfz10 on May 17, 2020 16:54:08 GMT -7
Unfortunately that’s a job I don’t feel comfortable doing. Any idea what the deal SHOULD charge to have the valves checked and adjusted if needed? I’ve only got a little over 2,000 miles on the bike and the owners manual says to have them inspected at 26,000. I’ll probably have it done at between 18k and 20k miles.
Post by mrcdharwood on May 18, 2020 5:33:25 GMT -7
I wouldn't bother at 2k miles. If the bike was 10 years old maybe.
Post by rracerfz10 on May 18, 2020 16:08:51 GMT -7
Oh no I said I was going to have them checked at 18-20k instead of the recommenced 26,000 and that the bike only has 2k on it so it’s still a ways off.
khanartist
Post by khanartist on May 28, 2020 18:20:18 GMT -7
Oh no I said I was going to have them checked at 18-20k instead of the recommenced 26,000 and that the bike only has 2k on it so it’s still a ways off. just curious, why would you have it checked before the recommended miles? my bike is almost due for the adjustment i think im at like 25.5k miles right now, and it has no issues. why throw off the maintenance periods?
Post by rracerfz10 on May 28, 2020 20:58:49 GMT -7
Because there are more than a few people reporting really tight exhaust valves well before the recommended vale check mileage.
Post by mrcdharwood on Jun 17, 2020 7:54:35 GMT -7
Just done mine.
All exhaust clearances tight. Min spec 0.2mm and mine were 0.1mm so way out.
Oh and that cam chain tensioner, what a 🤬🤬🤬 to get back in. It really was the hardest part of the job.
And make sure you've got glue to hold the new cam cover gasket on. That's a 🤬 job if you can't hold it on place putting the cover back on.
Notice lots of 🤬. It's that kind of job 😂
madmagpul
Post by madmagpul on Jun 18, 2020 15:57:48 GMT -7
Just done mine. All exhaust clearances tight. Min spec 0.2mm and mine were 0.1mm so way out. Oh and that cam chain tensioner, what a 🤬🤬🤬 to get back in. It really was the hardest part of the job. And make sure you've got glue to hold the new cam cover gasket on. That's a 🤬 job if you can't hold it on place putting the cover back on. Notice lots of 🤬. It's that kind of job 😂 What mileage did you end up completing yours?
Post by mrcdharwood on Jun 19, 2020 2:39:13 GMT -7
4 years old at 22k miles.
Post by Deleted on Jul 2, 2020 22:03:12 GMT -7
So the valve cover gasket is not the O-ring type that stays in place? What method do you suggest to use when doing the job alone? Something like RTV? Thx.
weirdo
Post by weirdo on Jul 2, 2020 23:04:08 GMT -7
Gasket like a T type and stuck in a groove of head cover, to fit firmly I was using silicone but honestly next time I'm gonna use liquid gasket to hold it in place. Cheers
Post by mrcdharwood on Jul 3, 2020 6:09:51 GMT -7
I ended up reusing the old seal. Gasket glue or silicon would work but use very sparingly.
Grease would also work and is what I am used on the parts I had peeled off.
mangiooon
Post by mangiooon on Dec 12, 2022 15:57:52 GMT -7
hi everyone
can someone tell me if the size of the valve shims is OD9.5mm please
for the yamaha mt10 sp 2019
