mario
Post by mario on Feb 16, 2019 10:41:59 GMT -7
Was out on the MT yesterday and I kept finding that on round abouts the front just felt really vague and like it was about to wash out. So I decided to finally setup my suspension today.
Took the bike out for 20-30 mins to warm up the suspension, then set it up as follows.
Front Forks
Rider Sag: 28mm (I was aiming for nearer 35mm, but I only got 28mm with all preload removed...I need softer springs being only 5’4” / 162cm and 70-ish kg)
Static Sag: 18mm (should be 10-15mm, confirms that the stock springs are too stiff for my weight)
Compression: 6 clicks out
Rebound: 3 clicks out
Tyre Pressure: 36 psi
Rear Shock
Rider Sag: 30mm
Static Sag: 8mm (should be 8-10mm), so the stock shock spring is just about ok for my weight)
High Speed Compression: 2.5 turns out
Low Speed Compression: 7 clicks out
Rebound: 4 clicks out
Tyre Pressure: 34 psi
The settings above totally transformed the bike. You can feel more weight on the front and it would be even more if the springs were right for my weight. However I now have loads of feel from the front, it doesn’t want to tuck on round abouts and it is just way more planted.
Hope this helps someone.
coachstarkey
Post by coachstarkey on Mar 15, 2019 13:42:18 GMT -7
So awesome to hear. I need to adjust mine. I'm 6'0, 220....feels super unstable in the corners.
How difficult is the adjustment? Where did you find instructions?
exuptoy
Post by exuptoy on Mar 15, 2019 14:47:48 GMT -7
Was out on the MT yesterday and I kept finding that on round abouts the front just felt really vague and like it was about to wash out. So I decided to finally setup my suspension today. Took the bike out for 20-30 mins to warm up the suspension, then set it up as follows. Front ForksRider Sag: 28mm (I was aiming for nearer 35mm, but I only got 28mm with all preload removed...I need softer springs being only 5’4” / 162cm and 70-ish kg) Static Sag: 18mm (should be 10-15mm, confirms that the stock springs are too stiff for my weight) Compression: 6 clicks out Rebound: 3 clicks out Tyre Pressure: 36 psi Rear ShockRider Sag: 30mm Static Sag: 8mm (should be 8-10mm), so the stock shock spring is just about ok for my weight) High Speed Compression: 2.5 turns out Low Speed Compression: 7 clicks out Rebound: 4 clicks out Tyre Pressure: 34 psi The settings above totally transformed the bike. You can feel more weight on the front and it would be even more if the springs were right for my weight. However I now have loads of feel from the front, it doesn’t want to tuck on round abouts and it is just way more planted. Hope this helps someone. These settings are EXACTLY the same as those dialled in on BJ's long term loan MT10 by James at JHS Racing in Bristol for Fast Bikes mag. The second person I have read in the last two weeks to confirm they make a heck of a difference. I'll have to dial mine in once the weather in the UK picks up.
exuptoy
Post by exuptoy on Mar 15, 2019 14:51:11 GMT -7
So awesome to hear. I need to adjust mine. I'm 6'0, 220....feels super unstable in the corners. How difficult is the adjustment? Where did you find instructions? You could pay for the Dave Moss subscription service ( davemosstuning.com ) where you can see all his videos including 2 on the MT10 specifically and actually learn what setting changes what or you can copy the above settings after watching this vid below.
Post by thefinn on Mar 15, 2019 15:27:44 GMT -7
I would go ahead and do your own reserach on what you like.
Dave moss has good free youtube videos about all these types of setups.
"Suspension for mortals" on youtube is a great crash course for everything that has to do with suspension and steering geometry.
I would taylor the bike to yourself (im 6'2 and 240 pounds and the springs are too soft for my weight to beware of that), this video is a really simple how to:
Set your preload and rebound, then dont touch them anymore and just play with the compressions. The compression is all about personal preference. There is no right or wrong (if its wrong for you, youll feel it. Bumps too rough or front dives uncontrollably wjen applying brakes).
If you adjust front compression, you need to match it with the rear low speed compression. Jump on your seat without holding any brakes and see if the bike lowers equally fast on both ends.
theculturalattache
Post by theculturalattache on Mar 15, 2019 17:56:49 GMT -7
I subscribe to the dave moss videos.
If your really clued up on suspension its probably not worth it but if your not(like me) I think its very good value, especially as Mr Moss just so happens to own a MT10!
It's where I got the idea to drop the yokes 20mm.
He's started putting out podcasts now on the mt10.
The current one is about luggage and the effect it has on suspension and the adjustments to make.
Recommended.
mario
Post by mario on Mar 19, 2019 8:40:02 GMT -7
These settings are EXACTLY the same as those dialled in on BJ's long term loan MT10 by James at JHS Racing in Bristol for Fast Bikes mag. The second person I have read in the last two weeks to confirm they make a heck of a difference. I'll have to dial mine in once the weather in the UK picks up. Truth be told, I got the settings from that video and wanted to use them as a base setting. However I avoided using their sag settings as setting static sag alone is a waste of time, seeing as the bike can’t ride itself. Static sag is only of any use to determine of spring rates are correct once rider sag is set. Since then I’ve realised the main thing I felt originally was the added weight on the front from sag being correctly set making the bike feel better. However the compression and rebound on the front were way off and didn’t work with the rear settings. They with too stiff and when hit with a gust of wind the bike would go into a mini tank slapper. When bouncing the suspension by hand after getting it warmed up on a run I could feel the rear rebound and compression was pretty good, but the front was way over damped and was too slow. Even when trying to bounce the whole bike the rear would move and the front would pretty much stay still, far too stiff. I’ve gone on to make changes to the fork rebound and compression. The bike no longer goes into mini tank slippers when hit by a side wind and the full bike bounces up and down simultaneously front & rear. I’ll keep tweaking here and there, as ultimately when it gets hotter ambient temps and the oil thins out I’ll need to add back some compression & rebound dampening. Oh, and I’ve also dropped a psi front & rear just to help generate a little more heat on these colder days. At the moment my settings are as follows... Front ForksRider Sag: 28mm Static Sag: 18mm (stock springs are too stiff for my weight) Compression: 15 clicks out Rebound: 7 clicks out Tyre Pressure: 35 psi Rear ShockRider Sag: 30mm Static Sag: 8mm High Speed Compression: 2.5 turns out Low Speed Compression: 7 clicks out Rebound: 4 clicks out Tyre Pressure: 33 psi
Post by Deleted on Mar 19, 2019 10:28:26 GMT -7
I always use 33 psi in the front, and 36 at the rear (always solo here); curious why you want more in the front. I only went softer overall a couple of clicks everywhere (except F comp, where I went 1, due to very little adjustment), leaving rear preload alone. I weigh 162 lbs in shorts and T-shirt, and that small change made a marked difference. I've only done one ride with aggressive riding, and bike felt great. I like a firm ride, since suspension is not adjustable, and don't like it bouncing around when ridden aggressively. Since I'm basically the target weight manufacturers tune their bikes with, I've never felt the need to mess with suspension settings other than maybe a couple of clicks here and there. This bike felt harder, but easing those 2 clicks put it where I'm used to. But will keep your numbers in mind if I find any untowards behavior as I ride it more aggressively this coming season.
mario
Post by mario on Mar 19, 2019 14:48:30 GMT -7
I always use 33 psi in the front, and 36 at the rear (always solo here); curious why you want more in the front. Because when you ride the rear will experience greater loads than the front, the rear has to provide the same grip as the front during cornering while at the same time having to put down circa 160bhp to the road. That extra load (work) the tyre has to do will generate more heat, the more heat you generate the more the pressure in the tyre will increase. So say I set tyre pressures at 35f & 33r after the tyres are gently warmed up on a short ride, but not pushing, it will give me good overall grip when pottering about, but when pushing hard the heat generated will put the front at say 36psi and the rear also at 36psi due to having to work harder and generate more heat. Then there is the larger contact patch you obtain with less pressure as well, which again helps with the grip required to put down the power, however that does not mean you should set pressures at 10psi in order to obtain a larger contact patch, there is a point where you reach diminishing returns. Then again depending on the tyre and how stiff the carcass is, you will see a lot of track riders running low to mid 20’s in the rear and high 20’s to low 30’s on the front straight off the tyre warmers.
Post by Deleted on Mar 20, 2019 23:02:34 GMT -7
You're forgetting rider weight. I've never seen any recommended pressures with the front tire more than the rear, but it's your call. The bike weighs 240 lbs at the front and 220 at the rear with a full tank, but the great majority of rider weight goes over the rear tire, so you need more pressure there. And of course we're talking STREET riding, not track, so not even close to being in the 20s. Anyway, for my light frame, 33/36 works great for me for both grip and ride. Mileage/life might not be ideal, but like you said, I want better grip.
mario
Post by mario on Mar 22, 2019 1:48:06 GMT -7
You're forgetting rider weight. I've never seen any recommended pressures with the front tire more than the rear, but it's your call. The bike weighs 240 lbs at the front and 220 at the rear with a full tank, but the great majority of rider weight goes over the rear tire, so you need more pressure there. And of course we're talking STREET riding, not track, so not even close to being in the 20s. Anyway, for my light frame, 33/36 works great for me for both grip and ride. Mileage/life might not be ideal, but like you said, I want better grip. Im not forgetting rider weight, and as you said the majority of weight is at the rear which again means the rear tyre will be under greater stress than the front and will generate more heat than the front, therefore increasing the air pressure in the rear when hot more than the front increases when hot. In regards to being in the 20’s I just use that as an extreme example on track, I would never run that low on the rear on the roads, so no need to shout (caps lock) about the fact we are talking about road / street and not track. Again, as an example, there was recently a WSBK team that was penalised for running the rear tyre too low in order to obtain more grip, so it’s not just me making it up, full race teams do the same, and again I use track as an example only that lower rear pressures provide greater grip.
aavmann
Post by aavmann on Apr 11, 2019 3:49:11 GMT -7
Lots of mentions of “Dave Moss”. This is a good thing. I have a friend that has persistently been telling me the value of his videos/tutorials and especially pertaining to the FZ/MT10. We all have invested a pretty penny to acquire the bike, why not spend a little more to really understand it? I have wrenched my own bikes for 16 years now and the knowledge I still have gained from a premium subscription to his site has been priceless. Guy covers everything motorcycles. Not trying to make this a plug here....just my opinion to share like my track riding buddy did to me.... Cheers
mario
Post by mario on Apr 17, 2019 7:14:50 GMT -7
Overall Dave is good, but he's not the best (otherwise he would be working in MotoGP and the likes), nor is he perfect. One example I have is just a lack of understanding of some of the tools he uses. In one video he puts wheels in the sun to see how warm they actually get and if you need tyre warmers on hot days which is fine, but then he uses and IR pyrometer to check the temps of his shiny chrome plated trailer ramp, which is pointless because these devices do not work on shiny reflective materials, then he used a tyre probe to check the tarmac / asphalt in the pits which is again pointless because the very end point of the probe is the only thing making contact and unlike a tyre your cannot press the entire probe into the tarmac to gain a true reading which is what is needed for these devices to operate accurately.
These might seem like small things, but they have a massive effect on readings and could cause you to get a reading of say 40*c when the real temp is well over 100*c, and I've seen that first hand when someone tried to use an IR pyrometer to check temps of they're shiny reflective brake discs, then burnt themselves after the device said the brakes were barely warm.
exuptoy
Post by exuptoy on Apr 17, 2019 9:17:43 GMT -7
You might be correct, however he is the first person I have seen reading a bike tyre to see what is happening at the suspension!
mario
Post by mario on Apr 17, 2019 9:23:38 GMT -7
You might be correct, however he is the first person I have seen reading a bike tyre to see what is happening at the suspension! Like I said, he is good and I have learnt a lot from him myself, but all I’m saying is don’t take every word as gospel. Take the information and try to cross reference, try to understand for yourself, make use of multiple resources inc books on the subject. Dave is a very good resource, but just remember he is human like the rest of us is all I’m saying
sackmonkey
Post by sackmonkey on Jul 2, 2019 14:53:14 GMT -7
I just got the courage up and copied the settings from the video to my bike. I set rear sag to 28mm (I weigh 220lbs). I'm blown away by the transformation of this bike. I'd been missing the way my other bike dives into corners (Fz6 with R6 forks/brakes) and kept telling myself I just had to get used to the brand new MT. Now I know it was more about setup. I'm absolutely floored with how it handles now!
Post by Zzz on Jul 13, 2020 21:47:13 GMT -7
Post by Zzz on Jul 13, 2020 21:48:06 GMT -7
exzackley
Post by exzackley on Jul 13, 2020 21:52:35 GMT -7
zgark35
Post by zgark35 on Aug 2, 2020 8:41:01 GMT -7
I'm 225 with all my gear and tried to adjust the sag and hydraulics but the springs were too soft and the shock needs a re-valve. There is a local shop in Lakeside CA, Quinten at Next Level Cycles that knows this platform very well and made it work perfect for me. He uses an R1 shock new piston and shims for your specs, new springs front and back. The bike is now perfect for me holds its line, very compliant and the suspension stays in the sweet spot in the middle of the travel range now. Check him out if you want your bike to work.
