Post by Cruizin on Sept 5, 2016 11:13:11 GMT -7
YAMAHA FZ-10 Oil Filters Part Number is # 5GH-13440-50-00 Click that to order cheap! K&N Filters have multiple reports of K&N oil filters failing and dumping oil out and all over rear tire! Multiple reports on multiple bike forum!! The following filters should thread up as well, but may or may not fit on exterior. AC-Delco PF2135 AMSOIL EAOM103 ARCTIC CAT 3201-044 ARCTIC CAT 3201-451 AUTOEDGE AL6017A Baldwin B1400 Baldwin B7285 CARQUEST 85358 CARQUEST 85365 ChampLab PH2876 ChampLab PH7015 ChampLab PH7028 DENSO 115010-5390 Donaldson P502067 EMGO 10-26920 EMGO 10-82230 EMGO 10-82251 Fleetguard LF3925 Fram PH6017A HASTINGS B7285 HASTINGS LF113 HIFLO HF198 HIFLO HF204 HIFLO HF303 K & N KN-198 K & N KN-303 K & N KN-303C KAWASAKI 16097-0002 KAWASAKI 16097-0003 KAWASAKI 16097-0004 KAWASAKI 16097-1058 KAWASAKI 16097-1061 KAWASAKI 16097-1063 KAWASAKI 16097-1064 KAWASAKI 16097-1066 KAWASAKI 16097-1067 KAWASAKI 16097-1068 KAWASAKI 16097-1070 KAWASAKI 16097-1072 LUBER-FINER PH2876 LUBER-FINER PH7015 LUBER-FINER PH7028 MELROE 6671057 MERCRUISER 35-822626 MERCRUISER 35-822626Q04 MERCRUISER 35-822626Q1 MERCRUISER Q03 MERCURY 35-8222626Q03 MERCURY G590000-G760299 MERCURY G760300-1B226999 MERCURY P086824-P325499 NAPA 1358 NAPA 1365 NAPA PS1358 Parts Master 61358 POLARIS 2520799 POLARIS 2540086 POLARIS 3084963 POLARIS 3089996 Purolator ML16817 Purolator ML16819 ROBIN 2576730111 SIERRA 18-7902 SIERRA 18-7909 SIERRA 18-7910 SIERRA 18-7911 SIERRA 18-7911-1 SIERRA 18-7913 SILVERLINE 21358 STP PH7028 TOHATSU (Marine) 3R0076150M TRIUMPH MOTORCYCLE T1210200 TRIUMPH MOTORCYCLE T1210444 WARNER PH7015 WESTERBEKE 30220
Post by Cruizin on Sept 21, 2016 0:11:06 GMT -7
If anyone finds that one of these Oil filters do not fit, update us here!
mateo
Post by mateo on Jan 9, 2017 11:31:48 GMT -7
Do you happen to know the part number for the oil drain plug gasket (AKA "crush washer")? I've been trying to find it online to purchase with certainty of getting the right one, without luck. Thanks.
**** Edit/update **** Based on the size of the oil drain bolt, I'm fairly certain the crush washers I have for my kid's Honda (car) will work perfectly for the FZ10 -- M14. I'm also pretty sure the ones I have for my Tacoma will work as well. Either way, it's $0.20 each.
The more you know....
latte
Post by latte on Jan 19, 2017 3:44:42 GMT -7
Hey guys, neither of the WIX filters worked for me, just a heads up. Wix 51358 Wix 51365 The threads bottom out before the O-ring comes in contact with the mating surface. I went for a K&N 204 for now as that was what was readily available and have HIFLO 204 filters on the way. Seems the WIX filters are not offset enough when compared to oem or other fitting oil filters.
Post by Cruizin on Feb 12, 2017 19:48:45 GMT -7
FYI, the above links for the Yamaha and K&N are very low priced, feel free to order!
Post by 0002s on Mar 11, 2017 16:11:05 GMT -7
Post by evitzee on Mar 11, 2017 22:33:57 GMT -7
If these are solid washers, and not crush washers, is there any need to replace them? There would seem to be no need to change it at each oil change.
Post by 0002s on Mar 11, 2017 22:37:54 GMT -7
If these are solid washers and not crush washers is there any need to replace them? When I first changed my oil I saw no need to change the solid washer. No other than it's what Yamaha recommends. Yes, if you follow Yamaha's recommendations to the letter.
Post by Deleted on Apr 7, 2017 9:23:04 GMT -7
I use Mobil 1 M1-108 and M1-110 on my bikes. These are car filters.
The FZ-10 can take the longer M1-110 since the filter comes out the side of the motor. Larger can, more filter media.
On the FZ1 the filter is behind the header and only the shorter M1-108 will fit. The M1-108 is similar in size to the OE filter.
And I hope its common knowledge by now...the base on the Purolator PL14612 was changed a few years ago and the filter adapter on the bike will bottom out on the base before the gasket can seal with the case. Your bike will leak oil. I did try the new Purolator Boss filter and the adapter still bottoms out but it tightens down enough for the gasket to seal. I only tried it once before I moved to Mobil 1.
speedydave
Post by speedydave on Feb 28, 2018 9:07:43 GMT -7
I had my oil changed at the dealer yesterday for the break in service. They used a yamaha 5GH-13440-60-00 filter. From what I can tell this one one supersedes the old one. Anyone know the difference?
fitzdrew516
Post by fitzdrew516 on May 25, 2018 15:28:34 GMT -7
The last two times my dealer gave me a “5GH-13440-60-00”, so a “60” instead of the “50”. I don’t know what that part of the part # code means. I think it might be length in mm based on the size of the box compared to another filter I got for my vstar (same # except “70”, not 50 or 60). Does anyone know what the deal is here? I assume it’s okay because the dealer sold it to me. Also interesting - I bought a filter for my vstar while I was there and I looked at the old oil filter box for my vstar and it was a “50” vs the “70” they just gave me ... I’m so confused.
Post by Deleted on Sept 30, 2018 17:19:35 GMT -7
Hey guys, does the M1-110A oil filter has the same oil pressure relief valve than the stock filter? I worry motorcycle oil filters might be different in that regard, since they typically call for thicker oil. The valve might bypass the filter a lot sooner than a stock one. I typically stick with OEM filters, but liked the M1 is longer, but want to know about the other specs. Thx.
kratosfz10
Post by kratosfz10 on Dec 21, 2018 9:24:27 GMT -7
Hey guys, does the M1-110A oil filter has the same oil pressure relief valve than the stock filter? I worry motorcycle oil filters might be different in that regard, since they typically call for thicker oil. The valve might bypass the filter a lot sooner than a stock one. I typically stick with OEM filters, but liked the M1 is longer, but want to know about the other specs. Thx. I've been trying to find this out also, would be nice to have the bypass pressure relief PSI rating listed somewhere, but I can't find any specs for the Yamaha brand 5GH-13440-60-00. I'm actually worried about the opposite. Most automotive filters are rated in the 11-17 PSI range, and I think many of the motorcycle specific filters are rated in the 8-11 PSI range. I would be afraid that using a filter with a higher PSI rating would NOT let the oil flow soon enough on a cold start-up when the oil is thicker, therefore causing a brief oil starvation situation.
kratosfz10
Post by kratosfz10 on Dec 21, 2018 10:51:37 GMT -7
I found some info:
I you go to the WIX site, you can find the filter for the FZ-10 (51358). WIX posts all the info for their filters, which is nice. The 51358 has a bypass valve rating of 8 psi. I then went to the amsoil site to look up their filter to see if they also post their info. While they don't post the bypass valve rating, they list the WIX 51358 filter along with their own filter, which seems a little odd. So it seems that the bypass valve rating for the FZ-10 should be closer to 8 psi, I'm guessing in the 8-11 psi range.
Granted, this still doesn't tell us the bypass valve rating of the factory Yamaha filter, but seeing this info, I'd be more comfortable using a filter in the 8-11 range vs 11-17.
Edit-- Well, the above may not be a good indicator. I just checked a couple of Royal Purple oil filters (10-2867 and 10-2876) on WIX's site, the filters that the WIX site cross-referenced to were 57356 and 51365, both of which show a bypass psi rating of 8-11. When I talked to Royal Purple about their 10-2867 and 10-2876 filters, they said they are rated at 11-17 psi. So it appears that the WIX filters may or may not be manufactured with the same bypass valve rating specs as the filters they cross-reference with.
I guess as long as the higher psi number of the lower psi rated filter overlaps with the lower number of the higher psi rated filter, maybe it's not that big of a deal.
The more motorcycle specific filters I look at on the WIX site, I see that they don't have a range, they just say 8, while most of the automotive filters have a range.
Post by Deleted on Dec 21, 2018 12:44:02 GMT -7
I'm actually worried about the opposite. I would be afraid that using a filter with a higher PSI rating would NOT let the oil flow soon enough on a cold start-up when the oil is thicker, therefore causing a brief oil starvation situation. That wouldn't be the case brother; the oil would just flow unfiltered (makes sense, no?), but it'd flow. Having a higher PSI than required is what could trigger your concern... but only if the filter gets clogged. I decided not to reinvent the wheel, especially with some engine failures already reported, so just ordered a pair of OEM filters, like I always do with all my vehicles. Will most likely change the oil before 5K every year, so not a concern at all to me. Bottom line is with the numbers you posted, I wouldn't use an automotive filter on a bike. Thank you for doing the research, and erasing the thought of doing that. Ha ha. Take care.
kratosfz10
Post by kratosfz10 on Dec 21, 2018 12:57:36 GMT -7
I'm actually worried about the opposite. I would be afraid that using a filter with a higher PSI rating would NOT let the oil flow soon enough on a cold start-up when the oil is thicker, therefore causing a brief oil starvation situation. That wouldn't be the case brother; the oil would just flow unfiltered (makes sense, no?), but it'd flow. Having a higher PSI than required is what could trigger your concern... but only if the filter gets clogged. I decided not to reinvent the wheel, especially with some engine failures already reported, so just ordered a pair of OEM filters, like I always do with all my vehicles. Will most likely change the oil before 5K every year, so not a concern at all. Take care. I don't quite follow why it wouldn't be an issue on cold start-up as well. If an oil filter has a higher bypass psi rating than it should, this means the pressure would have to reach a higher psi before triggering the bypass valve. If your motor is designed for a filter with a bypass valve pressure of 8 psi, and you install a filter with a bypass valve rating of 11-17, this means the bypass valve won't open until the pressure hits 11-17 psi, which is higher than spec. So the unfiltered oil won't flow until the pressure reaches a higher psi than what the motor was designed for. This is what would cause the oil starvation scenario. I would assume this would be true as the filter gets clogged with contaminants (as you mentioned) as well as on cold start-up when the oil is thicker. (I guess I could have qualified my statement by adding that the ambient air temperature would also be a factor) In colder climates the oil would be more viscous on a cold start-up than in warmer climates which could make the bypass valve rating on your filter even more important. Also, as I understand it, the range in the bypass pressure rating, for example, the 11-17 psi rating. The lower number indicates when the bypass valve starts to open, and the higher number indicates when the valve will be fully open. So, even if you have overlapping ranges, like say replacing a filter with a range of 8-11 with a filter that has a range of 11-17, when the motor is expecting full oil flow at 11 psi across the filter, the valve will just be starting to open, rather than being 100% open allowing full oil flow. I realize the change in psi from 8 to 17 may, in reality, not take long enough to even matter. But I like having good tangible data, even if it's for something that will probably never be an issue. So this is just me thinking out loud through all the data I have gathered today on this subject. For me, I think I'm just going to stick with motorcycle specific oil filters, or at least a filter with the correct bypass psi rating. While I'd likely never have an issue, I'll just feel better knowing the filter is within spec.
nmwbt
Post by nmwbt on Jun 18, 2019 8:13:17 GMT -7
nmwbt
Post by nmwbt on Jun 18, 2019 8:16:55 GMT -7
I just contacted the manufacturer for Mobil 1 filters. Come to find out they make motorcycle filters as well. Part number for the MT10 filter is M1-MC134. It has a bypass pressure of 15psi. I asked about the M1-110 as well. It also has a bypass pressure of 15psi. I imagine the car filters will be cheaper.
Post by Deleted on Jun 18, 2019 9:41:45 GMT -7
I decided to stick with OEM. I'm not going to push the envelope on OCI (oil change interval), so being a bit smaller should be of no consequence. Besides, with a few engine failures reported (even if we don't know if they were Yamaha's fault), it's much safer to use an OEM filter IMO, at least during warranty.
mattemike
Post by mattemike on Jul 12, 2019 5:53:53 GMT -7
Hi Flow makes oil filters with the same 17 mm nut welded on the end for easy removal. HF303RC is same filter but just has nut on end of the can. Shop where I work sells them for same price as std 303's. We don't sell K&N anymore after several failures. HF's are about 1/3 cheaper than K&N for an added benefit. They also make the RC in 204 size which fit other sport bikes as well.
