latte
Post by latte on May 6, 2017 18:06:03 GMT -7
If I let go of the bars with cruise control or when the front wheel is up from acceleration, the bike pulls to the right noticeably. More than what the crown of the road would do. I've checked the axle blocks on the rear wheel and they're equally spaced in the swingarm.. just wondering if this is a characteristic of the bike or if I've taken it off one too many sweet jumps.
Post by evitzee on May 6, 2017 18:10:16 GMT -7
Mine tracks straight when I remove my hands from the bars. I haven't heard of any tendency of the bikes to drift to the left or right.
kup0236
Post by kup0236 on May 6, 2017 18:30:59 GMT -7
Same here tracks straight.
latte
Post by latte on May 6, 2017 19:12:53 GMT -7
Hmmm, just put a micrometer to it and it's off by .5mm even though the hashes line up. We'll see if that fixes it.
Post by 0002s on May 6, 2017 19:15:22 GMT -7
Straight
kup0236
Post by kup0236 on May 6, 2017 20:08:03 GMT -7
Half a mm shouldn't affect it. But hopefully it's ok for you
Post by Deleted on May 8, 2017 9:30:57 GMT -7
Mine pulls right if I take my hands off the bars too! Several folks on the Euro forum were reporting the same so you're definitely not the only one. One guy reported tracking straight after he offset the axle adjustments by one full mark. No one said theirs drifted left.
tonysal
Post by tonysal on May 8, 2017 11:03:28 GMT -7
same here... mine tracks right if I take my hands off the bars. I just attributed it to the crown in the road. guess I need to check rear wheel alignment.
regards, Tony
audiblepop94
Post by audiblepop94 on May 9, 2017 7:19:18 GMT -7
Mine pulls right as well
thomascrown
Post by thomascrown on May 10, 2017 16:02:52 GMT -7
Mine pulls right too.
ovojay
Post by ovojay on May 12, 2017 7:16:36 GMT -7
Could the preload on the forks suspension not be the same? or forks not sitting flush in the triple clamp. I haven't tried mine yet, but I will definitely try it to see.
harrybalzak
Post by harrybalzak on May 12, 2017 8:12:00 GMT -7
Mine pulls right too, but I find that I'm not as comfortable cornering to the right, so I can use all the help I can get.
satorifz10
Post by satorifz10 on May 12, 2017 8:18:09 GMT -7
Mine pulls right too, but I find that I'm not as comfortable cornering to the right, so I can use all the help I can get. lmfao.. best post ive seen today by the way i noticed my bike pulling to the right when i was off the handebars on cruise control but the road was pitched down towards the right. will try it on a flat road and get back to this thread.
landmark518
Post by landmark518 on May 12, 2017 8:28:27 GMT -7
Yes mine definitely drifts right also. I have had this "problem" since day one. Would love to hear if there is a fix for this.
harrybalzak
Post by harrybalzak on May 12, 2017 10:09:14 GMT -7
Yes mine definitely drifts right also. I have had this "problem" since day one. Would love to hear if there is a fix for this. Don't take your hands off the bars. Problem solved. What else ya got?
audiblepop94
Post by audiblepop94 on May 12, 2017 15:20:42 GMT -7
Yes my bike pulls right, also, so did every single bike I owned (on flat surfaces too).. so just assume it's gyroscopic forces or something guys...
ogcrookedcop
Post by ogcrookedcop on May 12, 2017 22:42:24 GMT -7
My FZ09 never pulled to the right , I used to take my hands off the bars all the time coming up to lights to either shake my hands out or other things. The FZ10 has a significant pull to the right though. Anyone have a Yamaha tech friend ?
Post by Cruizin on May 12, 2017 23:32:26 GMT -7
My FZ09 never pulled to the right , I used to take my hands off the bars all the time coming up to lights to either shake my hands out or other things. The FZ10 has a significant pull to the right though. Anyone have a Yamaha tech friend ? Welcome to the forum, btw!
Post by Deleted on May 15, 2017 8:29:34 GMT -7
No pull on mine at all, with cruise and on back roads I frequently take my hands off bars...very straight. Are the tires mounted in the right direction? (long shot)
audiblepop94
Post by audiblepop94 on May 15, 2017 14:21:39 GMT -7
No pull on mine at all, with cruise and on back roads I frequently take my hands off bars...very straight. Are the tires mounted in the right direction? (long shot) Honestly, it's probably just a common alignment error when bikes are put together.. and all the guy's with bikes pulling right are just jumping on this bandwagon. Although, as stated earlier, every bike I have owned pulled right.
