Post by 2wheeldynoworks on Apr 30, 2017 17:11:41 GMT -7
Pipewerx Graves Graves with ex valve Austin Racing Dekelvic Akra 3/4
tonysal
Post by tonysal on May 5, 2017 10:59:40 GMT -7
Hey Nels (2wheeldynoworks),
have you tried a -10 with the LeoVince cat eliminator link pipe? if so, how'd it perform/sound?
regards, Tony
warnock
Post by warnock on May 6, 2017 5:55:56 GMT -7
Can you add the yoshimura 3/4 pipe
Post by Cruizin on Jun 10, 2017 14:05:12 GMT -7
grant123
Post by grant123 on Jun 10, 2017 15:44:14 GMT -7
This is great info! I really appreciate this.
The shocker was the graves evr, I expected more. Did you have the custom graves map on that adjusted the exup map?
Post by 2wheeldynoworks on Jun 12, 2017 12:00:23 GMT -7
All graphs are flashed ecu's tuned for the specific exhaust listed. Will try to wrangle all the maps into one place, having a hard time since they're on 4-5 different computers, my apologies for the delay.
Post by Deleted on Jun 13, 2017 11:55:42 GMT -7
So am I reading that right, the Graves with EXUP performed basically a tad bit more HP and a tad less TQ as the Graves with CAT delete? Seems like Graves slip on would be the way to go...
latte
Post by latte on Oct 18, 2017 8:30:21 GMT -7
So am I reading that right, the Graves with EXUP performed basically a tad bit more HP and a tad less TQ as the Graves with CAT delete? Seems like Graves slip on would be the way to go... I believe that's the Graves exhaust with their own EXUP valve and the tune accounts for the valve. Not slip-on and stock cat/EXUP.
av8er
Post by av8er on Oct 19, 2017 4:45:45 GMT -7
So am I reading that right, the Graves with EXUP performed basically a tad bit more HP and a tad less TQ as the Graves with CAT delete? Seems like Graves slip on would be the way to go... I believe that's the Graves exhaust with their own EXUP valve and the tune accounts for the valve. Not slip-on and stock cat/EXUP. That is vague and I would like to maybe get some clarification from 2wheel on that too. The first Graves is their 3/4 system with cat removed? And the Graves with exup is the EVO system?
latte
Post by latte on Oct 19, 2017 13:04:34 GMT -7
I believe that's the Graves exhaust with their own EXUP valve and the tune accounts for the valve. Not slip-on and stock cat/EXUP. That is vague and I would like to maybe get some clarification from 2wheel on that too. The first Graves is their 3/4 system with cat removed? And the Graves with exup is the EVO system? Thats how I interpreted it.
