michaelkostyniuk
Post by michaelkostyniuk on Apr 26, 2017 11:16:37 GMT -7
Not sure if anyone has looked into doing this, if it is even possible. But would it be possible to swap the new R1 cluster into the FZ 10?
Post by 0002s on Apr 26, 2017 11:44:19 GMT -7
Dash shows/controls the Ohlin suspension tuning settings that the ECU monitors and adjusts.
FZ-10 no Ohlin and no R1 motor setup.
MT-10SP with Ohlin swap might work.
botticelli
Post by botticelli on Apr 26, 2017 13:26:18 GMT -7
The r1-s screen might do the trick but its a pretty penny for a color screen i dont look at anyway
cassiofreitas
Post by cassiofreitas on Jan 13, 2019 8:56:08 GMT -7
Do you guys know of anyone that attempted to do the swap? If yes, may you put the link here. I'm really interested in this mod and right now I'm looking for an used MT-10SP cluster in good condition that I can buy on ebay.
Thanks
ghostrider1127
Post by ghostrider1127 on Jan 13, 2019 10:30:38 GMT -7
Possible to do , will not work at 100% BTW , you will need the left/right handlerbar switches aswel and wiring harness must be modded too. Did the test with SP cluster when swapped the R1 engine , as had to start it with R1 wiring harness (than modded Mt10 and r1 harness). If you are not more than into tech my suggestion is , do not try this home .
cassiofreitas
Post by cassiofreitas on Jan 13, 2019 16:43:55 GMT -7
Thanks for the feedback. I was planning to do a full swap on the harness and have the R1 cluster (with R1 Cluster, IMU, complete harness, hand controls, etc..) but if I do it I'll loose the cruise control and I really don't want to. When you say "it's not going to work 100%" would be possible to be more specific? Because you tested it so I'm assuming you saw exactly what is not going to work. And where did you but parts for MT-10SP? Because it's not sold in US I couldn't find anything, maybe you know a website in Europe that we can buy used MT-10SP parts. Again thank you for getting back, really appreciate it.
Cheers,
Cassio
