carlos1989
Post by carlos1989 on Jun 15, 2017 18:16:25 GMT -7
I checked mine today , both headlight are cracked .. 5400 km .The left one I can feel the scratch , might be a rock 😒 and the right one I can't feel it so it might the same issues as you have . I will try to have them repair on warranty .
I will post picture tomorrow And if you have a link where I can buy headlight protector that look good let me know . Thank !
jbodiedas
Post by jbodiedas on Jun 24, 2017 5:02:09 GMT -7
Checked mine today... No cracks but I'll be watching. I also own a 2016 R1S which has the same lights... Hoping neither bike becomes an issue but thank you for the heads up!
mprziv
Post by mprziv on Jul 19, 2017 13:24:30 GMT -7
Just curious how many of you guys run with high beams during the day? I have cracks too and was thinking that maybe could cause this problem since I run high beams when I ride during daylight hours. All the time, but my low beam is the one thats cracked..... I live in FL where everyone and thing is out to kill you.... dodged a gator yesterday. UPDATE******* Yamaha is covering the repair. The part is on order and surgery is scheduled for next Saturday. Our bikes are so new there isn't even a flat rate labor time for the head light replacement. Just washed my FZ10 today and noticed the high beam lens is cracked on the inside. I guess I'll be taking it to my local dealer and hoping they warranty it. Where in FL are you located?
sam07
Post by sam07 on Jul 19, 2017 19:01:21 GMT -7
All the time, but my low beam is the one thats cracked..... I live in FL where everyone and thing is out to kill you.... dodged a gator yesterday. UPDATE******* Yamaha is covering the repair. The part is on order and surgery is scheduled for next Saturday. Our bikes are so new there isn't even a flat rate labor time for the head light replacement. Just washed my FZ10 today and noticed the high beam lens is cracked on the inside. I guess I'll be taking it to my local dealer and hoping they warranty it. Where in FL are you located? Orlando
mprziv
Post by mprziv on Jul 20, 2017 7:57:47 GMT -7
Had the local dealership in West Palm Beach take some pictures of the cracked lens, they will submit to Yamaha and see if it will get covered under warranty.
I really hope it is covered, the bike is 2 months old and only 2,000 miles on it. Shelling out $600 for a new headlight assembly and swapping it out will be miserable. I'll update in case anyone else has similar issues.
Post by clayton on Jul 20, 2017 10:24:09 GMT -7
Hopefully Yamaha will update the lens for 2018 and cover all the 2017 that are having the problems. Must be faulty design
Post by evitzee on Jul 20, 2017 11:57:41 GMT -7
Hopefully Yamaha will update the lens for 2018 and cover all the 2017 that are having the problems. Must be faulty design Most likely it was a bad batch of lights from the supplier since this seems to be a random problem. But Yamaha should replace any cracked lenses whatever the reason.
sam07
Post by sam07 on Jul 20, 2017 13:21:22 GMT -7
My dealer sent pics in and Yamaha authorized it.
sam07
Post by sam07 on Jul 20, 2017 13:23:30 GMT -7
mprziv
Post by mprziv on Jul 23, 2017 13:23:50 GMT -7
Looks like Yamaha is covering the headlight replacement for me. Good news.
mhturbo
Post by mhturbo on Jul 24, 2017 6:13:22 GMT -7
Not heard of this issue over in the uk
Post by RedAndBlack on Jul 24, 2017 9:52:36 GMT -7
Thanks for the heads up! Definitely something to keep a look out on.
Yamaha should be covering this type of stuff under warranty. These cracks can and most likely are from the expanding and contracting of the lens as they are heated, and subsequently cool as we use our headlights. Definitely a manufacturer defect so definitely something that should be covered under warranty!
If you get a dealer that won't cover it, remember you can always contact Yamaha directly at their customer service line to state your case!
aledfranz
Post by aledfranz on Aug 8, 2017 10:05:45 GMT -7
Glad I found this post. I washed mine today and found the low beam is cracked right through the middle. Hopefully mine will be covered as well, 2 months and 3200 miles.
landmark518
Post by landmark518 on Aug 8, 2017 13:52:24 GMT -7
For anyone that this has happened to, can you confirm whether or not you do a lot of wheelies? I doubt there is any correlation but curious to find a the source of the problem.
sam07
Post by sam07 on Aug 8, 2017 16:22:19 GMT -7
For anyone that this has happened to, can you confirm whether or not you do a lot of wheelies? I doubt there is any correlation but curious to find a the source of the problem. Mine happened right after break in and I went easy on her.
Kameo
Post by Kameo on Aug 14, 2017 4:27:26 GMT -7
8,500 k's and no cracks....
thanos
Post by thanos on Oct 19, 2017 13:10:30 GMT -7
Mine too... low beam lens is cracked on the inside. Two months and 2.000km.
Post by clayton on Oct 19, 2017 16:04:42 GMT -7
Dang what’s up with these cracking? Are they glass or plastic? Waiting on 2018 to come out before buying me one. Hope they work the problem out. That’s an expensive fix once Warranty runs out.
iwasatoad
Post by iwasatoad on May 28, 2018 12:10:29 GMT -7
just had same thing happen washed prior to group ride saturtday no cracks went to wash sunday both are cracked. been paying attention to them since i seen this post. was 95 degrees out and no high beam since the pack was 100+ hard to miss us lol and still the high beam is cracked.
latte
Post by latte on May 29, 2018 7:46:46 GMT -7
Wonder if there will be a TSB for these? Mine is likely out of warranty but I see a small crack.
