maxxj
Post by maxxj on Nov 20, 2022 6:34:37 GMT -7
WOW, You seriously got 3-4 mpg more just by 520 and gearing change? Don't get too excited, that's like 12-15 miles to each fill up, so almost a gallon every other stop, for my area $3.90. Unless you're taking it to the track, just do your tooth count and leave a 525 on it. It's safer and most people that ride probably wouldn't even ride the 10 to it's full potential where they would need to go down a chain size.
smokinfz10
Post by smokinfz10 on Nov 20, 2022 7:17:51 GMT -7
17 FZ10, ECU reflash, Hindle exhaust and one tooth down on the front sprocket. At 78 mph and elevation at 5000ft in NM, I am getting 42mpg.
Post by mt10orc on Nov 20, 2022 22:30:00 GMT -7
I average about 32-33 with balanced riding. A little hooligan and a little cruising. I notice the best fuel economy is at 5-5.5k RPM. Flashed ECU by 2WDW and cat delete with LV can.
998noob
Post by 998noob on Nov 21, 2022 5:10:17 GMT -7
I average about 32-33 with balanced riding. A little hooligan and a little cruising. I notice the best fuel economy is at 5-5.5k RPM. Flashed ECU by 2WDW and cat delete with LV can. I get that mpg being totally stock. I imagine you have varies elevation changes in your rides in the North West?
Post by mt10orc on Nov 21, 2022 13:00:24 GMT -7
I average about 32-33 with balanced riding. A little hooligan and a little cruising. I notice the best fuel economy is at 5-5.5k RPM. Flashed ECU by 2WDW and cat delete with LV can. I get that mpg being totally stock. I imagine you have varies elevation changes in your rides in the North West? Yes we do. Live on the coast and generally ride in the coastal mountains.
Post by willl84 on Nov 22, 2022 6:02:34 GMT -7
I'm averaging 29.5 over the life of the bike (9600 miles) according to the dash. According to the Fuelly app though it's 28.049. But that can change slightly if you don't fill to the exact same level every single time.
998noob
Post by 998noob on Nov 22, 2022 8:59:42 GMT -7
I get that mpg being totally stock. I imagine you have varies elevation changes in your rides in the North West? Yes we do. Live on the coast and generally ride in the coastal mountains.Β I noticed when I'm in the GA mountains I get better mpg due to coasting on downhills. In contrast to the flat FL where mpg is worst.
Post by mt10orc on Nov 22, 2022 18:03:18 GMT -7
I'm averaging 29.5 over the life of the bike (9600 miles) according to the dash. According to the Fuelly app though it's 28.049. But that can change slightly if you don't fill to the exact same level every single time. Hooligan! π
Post by willl84 on Nov 23, 2022 10:27:11 GMT -7
I'm averaging 29.5 over the life of the bike (9600 miles) according to the dash. According to the Fuelly app though it's 28.049. But that can change slightly if you don't fill to the exact same level every single time. Hooligan! π The majority of my riding is commuting and the majority of that is stoplight,s half of that is stoplights on a road with 55MPH speed limit (so traffic is doing 70 realistically).
Post by mt10orc on Nov 23, 2022 19:55:26 GMT -7
The majority of my riding is commuting and the majority of that is stoplight,s half of that is stoplights on a road with 55MPH speed limit (so traffic is doing 70 realistically). Ok, ok Iβll give ya a brake then. The stoplights are probably what are killing ur MPG. We donβt have many stoplights here on the coast, thank goodness.
vulcanator
Post by vulcanator on Nov 27, 2022 10:31:43 GMT -7
Mine is stock, a mix of local and brisk riding gets me averaging 30-33mpg. When I commute on the freeway at 65-75 mph, I've averaged 36-38mpg. I'm think of going to a 42 rear sprocket like the 2022 MT to improve the mpg.
fatbob99
Post by fatbob99 on Dec 8, 2022 4:22:53 GMT -7
Mine is stock, a mix of local and brisk riding gets me averaging 30-33mpg. When I commute on the freeway at 65-75 mph, I've averaged 36-38mpg. I'm think of going to a 42 rear sprocket like the 2022 MT to improve the mpg. Iβm not sure the lack of oomph would offset the mileage woes for me . The grunt is part of the charm π
vulcanator
Post by vulcanator on Dec 9, 2022 14:38:58 GMT -7
Mine is stock, a mix of local and brisk riding gets me averaging 30-33mpg. When I commute on the freeway at 65-75 mph, I've averaged 36-38mpg. I'm think of going to a 42 rear sprocket like the 2022 MT to improve the mpg. Iβm not sure the lack of oomph would offset the mileage woes for me . The grunt is part of the charm π I'm also looking at a decat/link pipe, and a dyno reflash next Spring. The extra power & grunt gained will offset that gearing change.
weehe
Post by weehe on Dec 10, 2022 10:29:51 GMT -7
Iβm not sure the lack of oomph would offset the mileage woes for me . The grunt is part of the charm π I'm also looking at a decat/link pipe, and a dyno reflash next Spring. The extra power & grunt gained will to offset that gearing change. Previous owner had a 15T front sprocket installed. I changed it back the stock 16T and went 41t rear at the same time. No noticable change in mpg. I also have no issues doing a power wheelie in 3rd if I want. It did tame 1st and 2nd gear insta wheelies which was the goal.
