Post by slv on Feb 21, 2017 14:01:48 GMT -7
bhilker0604
Post by bhilker0604 on Jun 21, 2018 10:37:40 GMT -7
I ordered a fuel cap and got no hardware. Would you have any idea how to find sizes for the screws, O rings etc? Thank You for anything you can offer as help
Post by RedAndBlack on Jun 21, 2018 12:18:29 GMT -7
Reach out to the company you purchased from or the company who made it. I've always had companies send me missing items upon request.
chuckthebarber
Post by chuckthebarber on Jun 21, 2018 17:32:26 GMT -7
^this
bhilker0604
Post by bhilker0604 on Jun 26, 2018 10:04:00 GMT -7
TWM was very cool about sending the screw and gasket kits. I bought my Chinese TWM knockoff and waited 2 months and came with only the cap.
bhilker0604
Post by bhilker0604 on Jun 26, 2018 10:04:59 GMT -7
Get whatcha pay for...Lesson learned
Post by achrista on Aug 29, 2018 20:05:16 GMT -7
I am having issues getting the key out of the lock. If I lock the tank before removing the fasteners you've labeled as 2, the cap won't come of the tank.
If I remove the cap from the tank, I can't get the key out even when compressing the spring-loaded sealing mechanism on the bottom.
What was your solution?
Post by evitzee on Aug 29, 2018 21:12:04 GMT -7
I am having issues getting the key out of the lock. If I lock the tank before removing the fasteners you've labeled as 2, the cap won't come of the tank. If I remove the cap from the tank, I can't get the key out even when compressing the spring-loaded sealing mechanism on the bottom. What was your solution? Did you remove the security bolt under the fuel cap? Remove that first and then lock the cap and remove the key, then you can proceed to remove the three exposed bolts around the cap, problem solved.
Post by achrista on Aug 30, 2018 4:52:41 GMT -7
I am having issues getting the key out of the lock. If I lock the tank before removing the fasteners you've labeled as 2, the cap won't come of the tank. If I remove the cap from the tank, I can't get the key out even when compressing the spring-loaded sealing mechanism on the bottom. What was your solution? Did you remove the security bolt under the fuel cap? Remove that first and then lock the cap and remove the key, then you can proceed to remove the three exposed bolts around the cap, problem solved. Maybe I'm being dense, but even with the security bolt removed I was unable to remove the cap. I will try again this evening. Edit: I checked again this AM and when I lock the tank it seems to latch to the tank itself. If I remove 'fastener 1', lock the tank, and then remove 'fasteners 2', the cap is latched in. I wonder what the OP's solution for this is. I'll try compressing the springs and turning the key with the cap off this evening.
