Post by slv on Jan 11, 2017 19:55:06 GMT -7
*** Under Construction*** This will take me a couple weeks to get through. My ECU will need to go back to 2WDW for a tune to support the de-cat. I don't like to be down because I don't own a car, so I like to schedule things around my business trips. I'll be adding steps as I go. For now, some information and a mid-pipe. What is a catalytic converter? It's a chamber full of catalyst material (usually carbon mixed with metals and silica) that changes the ignition temperature of unturned fuel in the exhaust stream. Its function is a little more complicated, but not much. The effect is that unburned fuel in the exhaust gets burned in the catalytic converter so it doesn't pollute the environment (as much.) Because of its primary objective, it gets hotter than the jumper cables at an Alabama softball game. They also tend to be heavy. In larger engines like cars, and especially older designs like 1970's GM products, they build up soot and eventually choke the exhaust. On modern vehicles, the catalyst doesn't restrict flow much at all. Manufacturers do sometimes snake the gas path through curves and S shapes inside the device. This will slow the gas and can cause performance decreases. Why De-cat the bike? Two reasons. Weight savings. Cooler running. Is there a performance gain? Possibly a HP, maybe two. Could be four. Not a substantial gain in outright engine performance. The weight savings is a big gain in power:weight ratio. I'll weigh the cat when I remove it, but I read somewhere that it is about 18 lbs. The heat reduction is a big plus for valve integrity and overall engine longevity. So, I bought a mid-pipe. It's a Danmoto. Amazon.com $187 with free shipping. Yes, I took a chance, but the product looks pretty good. The welds are hand welds, but with good even flow and full penetration. The tube ends are chamfered, and the bung threads are clean and burr free. There is a small amount of weld material that purged through, but nothing major and nothing I would suspect of cracking. A few hundred dollars cheaper than some famous name versions. photo uploaderTo to be continued........
Post by slv on Jan 24, 2017 19:51:00 GMT -7
Removing the silencer and mid pipe. Sorry, I forgot to photo the heat shield before removal. Also note that I left the slip-on silencer attached to the cat. I'm putting the stock silencer back on with the mid-pipe.
Once you finish these steps, remove the loose fasteners and wiggle the cat gently while sliding it aft.
Post by slv on Jan 24, 2017 20:29:31 GMT -7
Post by slv on Jan 24, 2017 20:34:31 GMT -7
Install the new mid-pipe. first. Install the sensor plugs that you removed from the cat. No photo. make sure you're exhaust clamps are loosely installed and oriented correctly. (Just as you removed them.) Tighten all the fasteners and clamps. Fingerprints and grease will etch the surface of metal when heat is applied. Especially titanium.
Post by slv on Jan 24, 2017 20:45:28 GMT -7
Next up is removing the EXUP servo and cables.
For now though, I wanted to hear it. Definitely louder than I expected.
Post by Deleted on Jan 25, 2017 5:16:37 GMT -7
Great right up so far!!! Look forward to hearing your thoughts on it after riding it with the flash and the sound. Looks like you have the GoPro suction mount on the tank so more vids coming!!! LOL
Be interested in seeing full side pics to see the lines of the pipe with bike now too.
Post by Deleted on Jan 25, 2017 5:31:10 GMT -7
Oh and other video suggestions.......Video of bike rolling away from a stop at a normal take off pace, a vid of the bike rolling by at a normal constant in town speed (30-35mph) and accelerating flyby's.
And yes I am a demanding bastard!!! LOL!!!
Post by slv on Jan 25, 2017 6:54:09 GMT -7
Oh and other video suggestions.......Video of bike rolling away from a stop at a normal take off pace, a vid of the bike rolling by at a normal constant in town speed (30-35mph) and accelerating flyby's. And yes I am a demanding bastard!!! LOL!!! All part of the plan. I'm sending my ECU to 2WDW today. I'm going to Japan for a week and will be ready to run it properly upon return.
Post by Deleted on Jan 25, 2017 8:20:58 GMT -7
Awesome!! Safe travels my friend!!
guywithfz10
Post by guywithfz10 on Jan 26, 2017 23:27:38 GMT -7
Oh and other video suggestions.......Video of bike rolling away from a stop at a normal take off pace, a vid of the bike rolling by at a normal constant in town speed (30-35mph) and accelerating flyby's. And yes I am a demanding bastard!!! LOL!!! All part of the plan. I'm sending my ECU to 2WDW today. I'm going to Japan for a week and will be ready to run it properly upon return. Hopefully you get yours flashed quickly. I sent mine at a bad time because Nels was out in California for a few days. I'm still waiting for the call back.
