Post by stoltecmoto on Jan 3, 2017 20:46:11 GMT -7
 Stoltec Moto has the only drop-in springs for the 17+ FZ-10 (and naturally, the 16+ MT-10). We have two sources of supply, both of which are manufactured right here in the USA and available in a variety of rates. These springs are stock-replacement and do not require new spring spacers. Save yourself the hassle of calculating new air volumes and trimming spacers! Unlike most aftermarket springs, these are custom wound with a taper on one end to center the springs and reduce spring noise – just like the OE springs. Contact us for assistance in selecting a spring rate and oil weight. For more details or to purchase, see here: 17+ FZ-10 Linear Rate Fork Spring Kit
bogie
Post by bogie on Jan 3, 2017 21:21:17 GMT -7
Outstanding!! Your time and effort equals easy peasy for someone to order this upgrade!!
Thanks Nick!!
steves
Post by steves on Mar 16, 2018 14:01:44 GMT -7
Do you have installation instructions for these? Does one need to remove the fork tubes or use special tools? I'm interested in these, but would like to understand how hard it would be to install myself before I pull the trigger.
Post by stoltecmoto on Mar 17, 2018 10:33:36 GMT -7
Installation is pretty straight forward in that they are a direct swap for the OEM springs. The forks will need to be removed from the bike, and you will need a fork spring compressor to remove the fork spring cap. However, you do not need to remove the fork tube itself. If you would like to see greater detail of what's involved send us an email at sales@stoltecmoto.com
