gtayl09
Post by gtayl09 on Apr 22, 2024 8:32:16 GMT -7
Good morning all, hope life finds you all well. I took off my gas tank on my '23 MT 10 today to do some maintainence, put everything back together, made sure to hook up the fuel tank. The bike will not start now, no clue why. It turns over the starter motor, however it will not fire. Any suggestions are greatly appreciated.
Gabe
terrys
Post by terrys on Apr 22, 2024 20:24:04 GMT -7
Did you remember to plug in the fuel pump? You should hear that prime as soon as the ignition key is switched on.
Post by RedAndBlack on Apr 24, 2024 9:15:00 GMT -7
I mean I would just go back through and disconnect and reconnect everything. Make sure no hoses, including hoses for overfill and emissions return to the charcoal canister (Cali model) are pinched. Believe it or not, pinching these can cause starting issues.
gtayl09
Post by gtayl09 on Apr 26, 2024 12:24:23 GMT -7
I mean I would just go back through and disconnect and reconnect everything. Make sure no hoses, including hoses for overfill and emissions return to the charcoal canister (Cali model) are pinched. Believe it or not, pinching these can cause starting issues. Yep, completely forgot to plug in the wire harness. I was so fixated on the actual fuel line, I forgot that part.... Took it back apart, plugged it in, bike runs perfect again. Also on a sidenote, I was told to unplug the O2 sensors from Moore mafia after the tune, which of course deletes the cruise control. I hooked them back up, and between that and the lack of backfires now, it is so much more enjoyable. Best bike ever.
Post by RedAndBlack on Apr 27, 2024 15:55:49 GMT -7
It happens! I knew to suggest it because I've missed connecting everything to the tank before! Haha. Glad you got it figured out.
