howdager
Post by howdager on Apr 27, 2023 17:25:50 GMT -7
I just installed an Eastern Beaver (I know, great name) PC-8R fuse block. I use it to power my heated grips, heated vest lead and battery tender lead so I don't have to connect all of them to my battery. It has six switched and two un-switched terminals. The cool thing is that he has bike specific installations. The only one on the web page right now is for the Gen-1 bikes but when we discovered that the Gen-2 was slightly different he designed a kit for Gen-2. I just got the final version installed last weekend and it's great. The relay lead has connectors that match the factory connectors for the license plate light which is where the relay gets it's "on" signal. I also had one on my Africa Twin for 5 years and it worked great the whole time. Very high quality stuff. The new PC-8R version has the relay installed inside the fuse box so that it takes up less room under the seat. While he was building out the Gen-2 kit for me I had the Gen-1 PC-8 version (with external relay) installed and it still worked and fit ok under the seat but the new one is definitely better. easternbeaver.com/Main/Wiring_Kits/Fuseboxes/fuseboxes.html?gclid=CjwKCAjwuqiiBhBtEiwATgvixBHFTFLIiFfeb8PeZoTWqxu8jADQTL9wZ0npxQ_HdIzaD2qt4tvZ6RoCnEsQAvD_BwE
rj
Post by rj on Apr 30, 2023 19:08:24 GMT -7
Does he have the part number or listing yet for the Gen2?
Do you suggest reaching out to them direct?
